Trunk Divider/Insulation
Old January 24th, 2014 | 12:37 PM
schipperl's Avatar
What side if the Trunk divider does the insulation attach? The trunk side or the backseat side?
Old January 24th, 2014 | 03:22 PM
dfire25's Avatar
"Trying to fix her right"
Trunk side.
Old January 26th, 2014 | 12:04 PM
jfb's Avatar
jfb
I have seen both personally if you want the ultimate do both with super adhesive.
Old January 26th, 2014 | 12:25 PM
Welcome to the site.
What car, model, year is this for?
I have only seen it installed on the cabin side of 70-72 models. There are special metal tabs on the cabin divider the material hangs from. If you're installing something like FATMAT you can do whatever you want.
Old January 30th, 2014 | 12:13 PM
schipperl's Avatar
Year and Model
The vehicle is a 1970 Ols Cutlass w-31
Old January 30th, 2014 | 02:43 PM
The factory hung the cabin insulation on these 3 hooks.
Old January 30th, 2014 | 02:53 PM
dfire25's Avatar
Maybe I misunderstood the question.
I hung my insulation on these hooks first, then I hung the backing/divider piece (the cardboard piece) over this.
Old January 30th, 2014 | 09:42 PM
70Post's Avatar
Not used on that model at all....don't install it.
Old January 31st, 2014 | 01:19 PM
pcard's Avatar
70 Cutlass SX
The w31 was tripped down quite a bit. If you want to add some sound insulation the best place to put it is on the cabin side.
AzChevs
June 23rd, 2014 12:52 PM
70Post
August 28th, 2012 11:36 AM
halffast
April 24th, 2010 09:44 PM
ELECMAN
February 27th, 2010 07:20 AM
Trace Lippmann
March 14th, 2007 06:40 AM
