Trunk Divider/Insulation
Old Jan 24, 2014 | 11:37 AM
schipperl's Avatar
What side if the Trunk divider does the insulation attach? The trunk side or the backseat side?
Old Jan 24, 2014 | 02:22 PM
dfire25's Avatar
"Trying to fix her right"
Trunk side.
Old Jan 26, 2014 | 11:04 AM
jfb's Avatar
jfb
I have seen both personally if you want the ultimate do both with super adhesive.
Old Jan 26, 2014 | 11:25 AM
Welcome to the site.
What car, model, year is this for?
I have only seen it installed on the cabin side of 70-72 models. There are special metal tabs on the cabin divider the material hangs from. If you're installing something like FATMAT you can do whatever you want.
Old Jan 30, 2014 | 11:13 AM
schipperl's Avatar
Year and Model
The vehicle is a 1970 Ols Cutlass w-31
Old Jan 30, 2014 | 01:43 PM
The factory hung the cabin insulation on these 3 hooks.
Old Jan 30, 2014 | 01:53 PM
dfire25's Avatar
Maybe I misunderstood the question.
I hung my insulation on these hooks first, then I hung the backing/divider piece (the cardboard piece) over this.
Old Jan 30, 2014 | 08:42 PM
70Post's Avatar
Not used on that model at all....don't install it.
Old Jan 31, 2014 | 12:19 PM
pcard's Avatar
70 Cutlass SX
The w31 was tripped down quite a bit. If you want to add some sound insulation the best place to put it is on the cabin side.
AzChevs
Jun 23, 2014 11:52 AM
70Post
Aug 28, 2012 10:36 AM
halffast
Apr 24, 2010 08:44 PM
ELECMAN
Feb 27, 2010 06:20 AM
Trace Lippmann
Mar 14, 2007 05:40 AM
