Trac pac choke ??
Old Oct 24, 2023 | 04:28 AM
zl1 camaro's Avatar
Trac pac choke ??
Good day to all, I have a 66 trac pac, does anyone know if this should have a choke on the center carb ? My car has the choke flap, but is in the locked position & NO choke spring or rod... Maybe this is correct, if not, I will need to hunt down a choke spring & rod . Thanks in advance, Joe will probably know this I bet.
Old Oct 24, 2023 | 05:10 AM
It's not a hard question, most of us know the answer. The L69 tri carb setup was sold for street use, meaning that it had a choke on the center carb. The "track pack" (an unofficial term meaning the aftermarket retrofit of the shroud system) did not change that. Did the 66 W-30s (the 54 drag racing cars with the high rears) have chokes? That's a different question.
Old Oct 24, 2023 | 05:40 AM
Andy's Avatar
Yes they do have a choke on center carb, divorced choke.
Old Oct 24, 2023 | 05:53 AM
zl1 camaro's Avatar
Thanks much. now I have to find some parts I guess. Not a hard question to you maybe. lol
Old Oct 24, 2023 | 05:55 AM
zl1 camaro's Avatar
Sorry don't mean to sound stupid,[ DIVORCED CHOKE ??? ] Do you mean from the outer carbs
Old Oct 24, 2023 | 06:39 AM
Andy's Avatar
Originally Posted by zl1 camaro
Sorry don't mean to sound stupid,[ DIVORCED CHOCK ??? ] Do you mean from the outer carbs
no, just center carb. Non attached is what divorced choke means. Mike 66 3x2 442 can help you out with parts.
Old Oct 24, 2023 | 07:05 AM
zl1 camaro's Avatar
Thank you,,, you are the man !!
Old Oct 24, 2023 | 07:15 AM
Divorced choke means "bimetallic coil in the intake manifold and rod going up to carb" as in it is separate, ie, divorced, from the carb. This is as opposed to onboard bimetallic coil on the carb, and, later, opposed to the retrofit electric choke in the same housing on the carb.
Old Oct 24, 2023 | 07:43 AM
66-3X2 442's Avatar
I have new tri carb chole stats for sale. Comes with the stat,rod, bolt & retaining clip.
Old Oct 24, 2023 | 10:46 AM
zl1 camaro's Avatar
I never heard of that saying for this type of application. But yes I know some carbs come with the spring on the carb & some on the manifold.. thanks for explaining that..
Old Oct 24, 2023 | 11:16 AM
Andy's Avatar
As stated..separate..
Old Oct 24, 2023 | 12:56 PM
If you want some crazy stuff, look at how Ford did them with the hot air tube down to the exhaust manifold.
Old Oct 24, 2023 | 07:50 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Hi Tom. Here are a few GM choke styles...
Divorced choke, (not attached to the carb like my ex-wife).
It sits in a pocket in the intake above the exhaust gas crossover where it draws the heat to activate the bi-metal spring, pulling down to open the choke with heat.
Electric choke (integral/attached) The bi-metal spring is electrified to heat up. See the 12vdc tab for a female stake-on wire connector.
Hot air choke (integral/attached). The tube picks up heated air from a pocket in the intake (exhaust crossover) and feeds it into the bi-metal spring. Not the pic I wanted couldn't find a better one quickly, but you get it.
This pocket circled in red is where the divorced choke fits.
Old Oct 25, 2023 | 04:53 AM
zl1 camaro's Avatar
Hey thanks a bunch for all the info, all you guys are great.. The divorce statement is what [off set me...]
Old Oct 25, 2023 | 10:36 AM
zl1 camaro's Avatar
Choke
Old Oct 25, 2023 | 10:55 AM
zl1 camaro's Avatar
WOW, Ok Great,, how do I get this & what are you looking for it $$$$$
Old Oct 25, 2023 | 11:52 AM
66-3X2 442's Avatar
They are $87 with free shipping. I need to see a picture of your center carb to make sure what you need. The right side of the carb.
Old Oct 25, 2023 | 09:26 PM
Exactly how the factory hot air choke was plumbed on my 62 F85.
Old Oct 26, 2023 | 04:26 AM
zl1 camaro's Avatar
OK let me get some pics to you. thank you
Old Oct 26, 2023 | 05:06 AM
I understand the engineering point, the exhaust manifold will get warmer, sooner, move some air up there and get the choke moving, but I think it's a lot of materials, and,
it's not really indicative of the condition of the carb and intake.
70indyolds
Jan 9, 2020 07:10 AM
oldolds88
Feb 5, 2017 07:38 PM
flatlander442
Mar 3, 2016 05:51 PM
Gunfreak25
Feb 11, 2011 02:44 AM
1973olds98
Aug 25, 2009 06:00 AM
