Is this too lean?
Old Jun 22, 2021 | 07:32 PM
Donaldbabineau's Avatar
Is this too lean?
I pulled this plug from the #6 cylinder of my 455. I see a lot of images online of what is too lean and what is optimal and sometimes they look the same. This looks lean to me but I am far from knowledgeable at reading plugs. My 455 has 1970 E heads, but the carburator is a numbers correct 73 I bought online which I assume is jetted for a 73. Since the jetting is likely set for smog era J heads, would that potentially lead to a lean mixture if flowing through less restrictive E heads?
Old Jun 23, 2021 | 06:21 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Your compression ratio is the same, the carb should be close. Did you add headers? That will lean out the mixture.
Old Jun 23, 2021 | 06:34 AM
I have headers. The CR isn't 8.5:1. Pistons are v-notch shallow dish 30 over and look like stock replacement 1970 pistons.
Old Jun 23, 2021 | 09:26 AM
Jeff Stout's Avatar
I would prefer to cut off threads and look at porcelain further down then what is visible here. What it shows here is not really lean to me. Timing looks ok by looking at ground strap. Could have more but its really close.
Old Jun 24, 2021 | 12:01 AM
Ozzie's Avatar
It may be a bit on the lean side. It would be interesting to know what air/fuel ratio it operates at most of the time. Sometime the heat range of the spark plug can also affect their appearance.
Old Jun 24, 2021 | 06:35 AM
As long as the engine doesn’t buck, miss or jerk at cruising speed,the engine isn’t too lean. Part throttle, the engine isn’t under enough load to hurt anything. Don’t run a engine lean at full throttle, bad things happen!!
trevor s
Apr 2, 2015 12:44 PM
Olds_71_442
Dec 4, 2012 10:25 AM
Beeks69
Jun 25, 2012 04:06 PM
btrbill
Apr 1, 2012 05:53 PM
Coltonis
Nov 29, 2007 12:24 PM
