Are these date codes?
Old Dec 10, 2021 | 02:03 PM
72455's Avatar
1972 U code Supreme
Are the numbers on these AC brackets date codes?
Old Dec 10, 2021 | 03:11 PM
Yes. 336 is the 336th day of the year, so Dec 2 (or Dec 1 in a leap year). 2 is Jan 2.
Old Dec 10, 2021 | 04:15 PM
I tried my best to learn something from this thread. I'll agree 336 would be a likely number for the 336th day of a calendar year. If only I could find the number "336" located in one of the images I might be able to learn something here. WTF are you talking about, Joe?
Old Dec 10, 2021 | 04:21 PM
The little plates retained with screws to the casting core is the date code
Old Dec 10, 2021 | 04:26 PM
Holy Guacamole. I stared at those images & lost my mind. Wow, got it. Thanks!
Old Dec 10, 2021 | 04:45 PM
72455's Avatar
1972 U code Supreme
Thanks Joe...what would the year be, and how do you tell?
Old Dec 10, 2021 | 05:32 PM
You would tell by the model year of the car they came off of, unfortunately. 391366 was used on all 1966-72 Cutlii with A/C and all 1966-78 Toronados with A/C, for example.
Old Dec 10, 2021 | 06:48 PM
72455's Avatar
1972 U code Supreme
So each year didn't have a specific code, it was just the Julian date code?
Old Dec 10, 2021 | 10:36 PM
4Speedy's Avatar
Correct!
It could be any year.
Old Dec 11, 2021 | 01:58 AM
Tri-Carb's Avatar
At the time GM used several different methods for date coding. Some methods do use use one, and some use two digits, to signal the year of the part. In addition, some indicate information like shift and time of manufacture.
Old Dec 12, 2021 | 06:59 AM
F-85 4-4-2's Avatar
Since we're on the topic, how were those (Julian) date codes affixed to a casting mold, and what was their material(s) of construction?
Old Dec 12, 2021 | 07:06 AM
I don't have first-hand knowledge, but it appears that these were simply stamped straps of thin sheet metal that were screwed to the mold core.
Doug Carner
Tech Editor's Desk
Oct 18, 2020 10:14 AM
72455
Mar 29, 2019 08:32 AM
Turnpike
Tech Editor's Desk
Nov 8, 2017 08:56 PM
dnmfranco
Aug 19, 2014 06:59 PM
Bernhard
May 26, 2014 02:17 PM
