Tach Interference
Old May 17, 2014 | 11:04 PM
Magna86's Avatar
Tach Interference
Can the coiled water temperature sensor wire cause interference to the tach signal wire? After I installed the gauges I started having issues with my tach. The tach worked fine before I did the gauges. With the car running tach runs fine if the ground is disconnected, connect the ground and it sits at zero. When tach is working without the ground connected you turn on the lights the tach goes to zero. Turn the lights off and it works. There are other wires near the signal wire from the gauge install so not sure which is causing issue. Can you shield the tach wire with rubber hose to protect from interference? I havent dug into this yet so asking ahead of time.
Old May 18, 2014 | 03:58 AM
No.
Starting with the fact that the water temp capillary tube is grounded, and ground wires can't do that, but even if it wasn't grounded, still No.
How is your engine ground strap?
Old May 18, 2014 | 02:10 PM
Magna86's Avatar
Thanks Eric. I wasn't sure but thought it wouldn't cause an issue. The tach worked fine after I installed it before I installed the gauges. Will remove the gauge wires one by one to find problem wire.
AZ455
Sep 22, 2022 06:56 PM
Olds Dad
Aug 15, 2012 11:38 PM
Doc350s
Mar 26, 2012 09:58 AM
fmbjogger
Oct 27, 2011 07:10 AM
68conv455
Jan 3, 2009 07:40 AM
