455 exhauset header interference problem help needed
Old Jan 1, 2009 | 02:07 PM
68conv455's Avatar
I've got a 68 cutlass convertible with a 455. I purchased thorley headers for the cutlass and 455 and just discovered that the passenger side header contacts the fire wall. The header tube just barely touches it. What should I do. I purchased the headers almost 1 year ago so I'm assuming returning them is not viable. The headers also have a nice nickel coating which would be a shame to damage with heat. Should I e-bay them and start over? Help.
Old Jan 1, 2009 | 02:45 PM
64Rocket's Avatar
Does it touch the firewall or the heater box?
I would make adjustments in the firewall or the box whichever is necessary. Also put some insulating rap around the pipe in that spot.
Gene
Old Jan 1, 2009 | 02:48 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
That doesn't look too bad. You were fortunate if that is the only problem you had with the fit. My passenger header hit the firewall as well. I just beat the snot of it though. You could always notch out the firewall and weld in a cup.
Old Jan 1, 2009 | 03:25 PM
don71's Avatar
same but different
If it were me, I would try to clearance the firewall. Probably use a long pry bar against the wall with the header as the fulcrum. Use a rag or something to keep from scratching anything thing.
Worst case, remove header, and clearance the firewall with a hammer.
Old Jan 1, 2009 | 04:27 PM
I vaguely remember a similar problem with a set of Thorley headers on my 68 442 that I built in high school (in the last century...).
Old Jan 1, 2009 | 05:32 PM
88 coupe's Avatar
Junior Member
Was it a convertible?
Norm
Old Jan 1, 2009 | 07:05 PM
gearhead1218's Avatar
This calls for a very precise adjustment with a BFH.
Old Jan 1, 2009 | 07:55 PM
Norm
Holiday Coupe. I suspect the problem is production tolerance stackup.
Old Jan 2, 2009 | 08:43 AM
citcapp's Avatar
Remove header. Use a 9 pound adjustment tool and create a indent in the area required.
Old Jan 2, 2009 | 09:16 AM
Oldsguy's Avatar
Past Administrator
I agree with all the recommendations as any/all of them will work. I pose one question though. Is is possibly caused by worn engine mounts? If so, obviously, that might be a fix. I realize that if the mounts were to wear then more than likely the engine would sit a little lower, not back, but just sharing that idea...
Old Jan 2, 2009 | 09:59 AM
1964f-85's Avatar
header fit
I put headers on my 455, 64 cutlass and had the oposite problem, the headers were hitting the passenger side crossmember, what I found out is that the aftermarket engine mounts are sloppy, with factory exhaust manifolds this doesn't pose a problem. I fixed it by welding the holes on the mounts where they bolt to the block closed and redrilling them to raise the engine up, you may be able to do the same, in the opposite direction to lower the engine away from the floorboards. as long as the oil pan doesnt hit the rossmember you should be fine.
Scott
Old Jan 2, 2009 | 08:17 PM
68conv455's Avatar
Norm asked if it was a convertible. It is.
Is there a difference at the firewall on the convertible?
I think I'll try to make some fine adjustments to the firewall, and, fine adjustments to the header tube.
Thanks for the advice.
Old Jan 2, 2009 | 10:01 PM
88 coupe's Avatar
Junior Member
Originally Posted by 68conv455
Norm asked if it was a convertible ........
It was that, or ask him if it was a Supreme. Explanation is below.
........ Is there a difference at the firewall on the convertible? ........
Header catalogs say there is a difference (in convertibles and Supremes) but no one knows where, or what, it might be.
Header fitment (or misfitment?) can occur with one of two identical cars. Joe_p's "tolerance stack" theory, makes perfect sense to me, especially if space is limited.
Norm
Old Jan 3, 2009 | 12:32 AM
red rocket's Avatar
Remember that your big block will move under power but the firewall/heater will not. I had to do some banging with my 67 CS convertible 455 but no problems now.
Old Jan 3, 2009 | 05:26 AM
True, however unless you're drag racing in reverse, the passenger side rotates down.
Old Jan 3, 2009 | 05:38 AM
Not to high jack this thread, but is this rotation what can cause cracks in the drivers side pillar. I have a friend who bought a real 69 W-30 that came with slicks. [and was drag raced] It has a small crack in drivers side pillar.
Old Jan 3, 2009 | 07:11 AM
But you did...
Yes. Repeated shocks from launching the car causes the body to torque, resulting in fatigue cracks.
Old Jan 3, 2009 | 07:34 AM
68conv455's Avatar
Drag race in reverse?
I think you just invented a way to race imports and make it a fair race.
Old Jan 3, 2009 | 07:40 AM
But you did...
My sincerst appologies
In the future, I will endeavor to control my inquisitivness.
But thanks for the prompt and accurate [as always] answer
AZ455
Sep 22, 2022 06:56 PM
rootney
Jan 1, 2014 07:22 PM
Olds Dad
Aug 15, 2012 11:38 PM
Doc350s
Mar 26, 2012 09:58 AM
fmbjogger
Oct 27, 2011 07:10 AM
