8 track acceleration interference
Old Oct 27, 2011 | 04:07 AM
fmbjogger's Avatar
Original 8 track in '75 Delta that experiences a " whirring" interference when accelerating. Anyone know the cause and cure ? Thanks !
Old Oct 27, 2011 | 07:00 AM
Lady72nRob71's Avatar
Does the FM radio do the same? If so, then check the ground connections from the radio under the dash.
If only the tape player does it, then it is most likely an issue internal to the radio unit.
Old Oct 27, 2011 | 07:10 AM
There should be a condenser on your coil! It's probably weak! Also, as mentioend above, check your grounds, especially make sure your antenna is tight!
Also poor quality, and/or leaky spark plug wires will cause it!
AZ455
Sep 22, 2022 06:56 PM
rootney
Jan 1, 2014 07:22 PM
Olds Dad
Aug 15, 2012 11:38 PM
Doc350s
Mar 26, 2012 09:58 AM
68conv455
Jan 3, 2009 07:40 AM
