Swapping Out Instrument Lights to LED--What Color Temp?
Old November 27th, 2016, 07:12 PM
J.O.'s Avatar
Before I buy replacement 194 & 161 LED's for the tach, speed, & gauges what temperature color bulbs best matches the originals? 6500K, 4100K, or 3000K -- Is $6 a typical price?
J.O. is offline
Old November 28th, 2016, 04:49 AM
72 Olds CS
RetroRanger's Avatar
I would guess warm 3000k would be closest. $6 a piece seems pricey, I just bought 8 of the dome light versions for $6 on Amazon.
Can you dim these LEDs ?
RetroRanger is offline
Old November 28th, 2016, 06:21 AM
jozw30's Avatar
3000K is the closest to incandescent in that list (should be under 2700K actually) These likely won't dim, so if they don't light up right away, check your ignition switch & make sure it's not dimmed.
Many of those little lamps are polarity sensitive too, so if they don't light right away, flip them in the socket.......
jozw30 is offline
TahoeRob
August 20th, 2016 03:18 PM
deltaroads
October 26th, 2015 04:08 PM
TripDeuces
November 19th, 2014 05:33 PM
LAolds
August 19th, 2013 11:33 AM
veltboy618
January 7th, 2009 05:31 AM
Quick Reply: Swapping Out Instrument Lights to LED--What Color Temp?
