Swapping Out Instrument Lights to LED--What Color Temp?
Old Nov 27, 2016 | 07:12 PM
J.O.'s Avatar
Before I buy replacement 194 & 161 LED's for the tach, speed, & gauges what temperature color bulbs best matches the originals? 6500K, 4100K, or 3000K -- Is $6 a typical price?
Old Nov 28, 2016 | 04:49 AM
RetroRanger's Avatar
72 Olds CS
I would guess warm 3000k would be closest. $6 a piece seems pricey, I just bought 8 of the dome light versions for $6 on Amazon.
Can you dim these LEDs ?
Old Nov 28, 2016 | 06:21 AM
jozw30's Avatar
3000K is the closest to incandescent in that list (should be under 2700K actually) These likely won't dim, so if they don't light up right away, check your ignition switch & make sure it's not dimmed.
Many of those little lamps are polarity sensitive too, so if they don't light right away, flip them in the socket.......
TahoeRob
Aug 20, 2016 03:18 PM
deltaroads
Oct 26, 2015 04:08 PM
TripDeuces
Nov 19, 2014 05:33 PM
LAolds
Aug 19, 2013 11:33 AM
veltboy618
Jan 7, 2009 05:31 AM
