Suspension/Steering Part Brands
I've always had good experience using Moog, springs, ball joints, tie rods, center link, idler arm sway bar links and bushings. Beyond that I haven't done much work, i.e. control arm components things that modify the factory geometry.
Good Luck with the build.
^^^^this.
You may want to consider tall ball joints, if you're going to be in there. The lowers will drop the front a little, and they may not fit 14" wheels. It was one of the best things I've ever done to the car, as far as handling.
ProForged is offshore (FYI)
