Straitening front bumper
Old Nov 8, 2022 | 04:39 AM
Bfg's Avatar
Bfg
I have a 71 Cutlass and the front bumper is slightly tweaked but otherwise has very good chrome, can these bumpers be straightened without having them rechromed?
Old Nov 8, 2022 | 05:01 AM
Post a picture of your bumper, minor tweaks can be fixed with a come along and a hammer with blocks of wood.
Old Nov 8, 2022 | 06:53 AM
Tedd Thompson's Avatar
Or take it to a chrome shop and have them put it back straight, they do it every day and are good at it generally..Tedd
Old Nov 8, 2022 | 09:14 AM
Bfg's Avatar
Bfg
That’s a good suggestion Oldcutlass, as you can see it’s not too bad, if I hook the come along under the bumper guard and try hitting the corner of the bumper back with a block of wood it might straighten it, does that sound good? Otherwise I can do what Ted mentioned
Old Nov 8, 2022 | 10:04 AM
You should be able to straighten that yourself with a come along. You may have to remove it if the come along does not work with it on the car.
Old Nov 8, 2022 | 10:10 AM
Bfg's Avatar
Bfg
Ok thanks, I’ll give it go
Old Nov 9, 2022 | 04:04 AM
prlynch01's Avatar
When I bought my 70 442 the front bumper did not fit very well. I bought a Hustler Stick which is a product made for straightening steel bumpers. Unfortunately I did not take any before or after pictures, but the results were very good.
Old Nov 9, 2022 | 07:05 AM
Interesting thread. Here's a video about using a hustler stick to straighten a bumper. He makes it look easy, I'd be afraid I'd screw something up. Although both bumpers on my Ford truck are bent.
Old Nov 9, 2022 | 07:47 AM
Bfg's Avatar
Bfg
Very interesting video, I’m definitely going to look into this. He makes it look so easy!
Old Nov 9, 2022 | 01:55 PM
cherokeepeople's Avatar
my 66 had an issue similar to that.and beings i had it off i used my cherry picker .i had to set the front of it on blocks to get the bumper under it but then i ran a chain around the bumper with a chunk of conveyor belt to keep from scratching the chrome then just jack it up slowly stopping once in awhile to check to see how close it was..
Old Nov 9, 2022 | 02:11 PM
GN1220's Avatar
Looks like the whole front is pushed in and up, I don't think beating on one corner will do anything. I'd say if you pulled from the center out and down the sides would correct themselves.
Old Nov 10, 2022 | 11:03 AM
I watched a few more videos on using a hustler stick. It might be worth getting one and then hitting up the salvage yard to "practice" before using it on your Olds.
Old Nov 10, 2022 | 11:17 AM
Bfg's Avatar
Bfg
I haven’t seen any cars with chrome bumpers around here for some time
Old Nov 10, 2022 | 03:01 PM
Dodge trucks
Old Nov 11, 2022 | 10:30 AM
Yeah, even the Ford trucks from 20 years ago still had chrome bumpers. There should be plenty of those in the salvage yards still... Well, I guess not since Ford builds such a tough truck. Now Dodges and Chevies on the other hand.
67Rocket
Mar 10, 2019 06:00 PM
DreamSupreme71
Aug 25, 2013 04:12 PM
charlierogers
Mar 15, 2013 05:03 AM
JeremyTA
Care and Appearance
Jan 30, 2013 01:58 PM
78ChevOlds
Body work
Jul 2, 2010 06:11 PM
