Stop leak
Old Oct 1, 2020 | 06:40 AM
Bfg's Avatar
Bfg
Stop leak
This is not related to any car but concerns a John Deere 318 lawn tractor that is around 30 years old. It has developed a oil leak from a front seal. Does anyone recommend the use of stop leak, the pros and cons? I personally am not a big fan of a quick fix remedy. I would sooner repair it the correct way.
Old Oct 1, 2020 | 06:53 AM
I wouldn't bother with snake oil. Does your tractor have a diesel engine in it? If so, it might have an oil cooler that could be clogged. None of the snake oils are well rated anyways.
Old Oct 1, 2020 | 08:49 AM
Bfg's Avatar
Bfg
Gas powered, no oil cooler
Old Oct 1, 2020 | 12:25 PM
rustyroger's Avatar
'87 Delta 88 Royale
Check you don't have a blocked breather and change the seal, Surely the best way to fix it long term. Snake oil remedies normally make the seals swell, temporarily helping cure leaks, but not a proper fix.
Roger.
allyolds68
Jun 13, 2014 05:28 PM
deaddds
Mar 29, 2012 09:03 AM
71 Cutlass
Feb 28, 2012 10:47 AM
jcddyy
Aug 19, 2011 01:27 PM
vmathy
May 30, 2011 08:50 PM
