starter issues still
Old Apr 12, 2014 | 03:48 PM
Niko's Avatar
You guys have helped me before. Im still having problems. I have a 89 olds wiht a 77 engine. They put an aftermarket iginition on. The back of the key ignition has markings for Battery st (presumably starter) acc and ignition. Does the wire that is hooked the battery marrked area go directly to the battery?
Also, I hooked up the starter i thoght correctly but when yuo go to startit it actually turns over in the on positon and to the left in the acc positoin....
HELP
Old Apr 12, 2014 | 05:17 PM
1970cs's Avatar
Lansing built
Yes, in theory! Battery voltage or hot to that terminal at all times.
Your start position should be wired or putting 12 volts to the S terminal on the solenoid on the starter.
But with a cobbled switch and wiring, you may have to start from fresh.
Pat
Old Apr 12, 2014 | 06:32 PM
Niko's Avatar
So the wire marked ST is supposed to go the the S terminal? Which wire goes to the other terminal?
Old Apr 12, 2014 | 07:58 PM
The other terminal on the starter is for resistor wire bypass, if you were running a points distributor it would go to the + side of the coil during the start cycle. If your running an hei it may or may not be needed to supply voltage during the start cycle.
Old Apr 13, 2014 | 07:10 AM
Niko's Avatar
Thanks.. But where does the wire off the ignition marked ACC go?
Old Apr 13, 2014 | 11:36 AM
m371961's Avatar
The ACC is for the things you want powered with the key in the accessory position, for example the radio. With the key in run, the ignition and the acc terminals will be hot.
Old Apr 13, 2014 | 11:52 AM
Niko's Avatar
Where does the wire get hooked?
Niko
Apr 13, 2014 09:45 AM
Murco
Oct 29, 2011 05:54 PM
navvet
May 23, 2011 02:49 PM
major tom
Jul 27, 2010 11:12 PM
