Stamp on the block deck
Old Jan 31, 2022 | 12:16 AM
Donaldbabineau's Avatar
Does anyone know what the "B" stamped on the decks of my 455 mean if anything. they are located between the water ports behind cylinder #1 and the same location on the opposite bank of cylinders. The block is a 1973 455, but don't know what it came out of.
Old Jan 31, 2022 | 08:30 AM
67OAI's Avatar
Old(s)GuysRule
The letter code as stamped indicates the factory finished cylinder bore size so that the correct matching piston size is picked for use in that/those cylinder(s) during assembly.
Old Jan 31, 2022 | 09:30 AM
interesting. I assume that accounted for the wear on the machine parts over the production run.
Old Jan 31, 2022 | 09:58 AM
68442's Avatar
Nothing to do with wear, It was all about these engines being part of mass production. And the WIDE varied tolerances that were acceptable.
Old Jan 31, 2022 | 02:24 PM
v8al's Avatar
Registered Olds Owner
From the 1972 CSM. 73 is probably similar.
Old Jan 31, 2022 | 02:34 PM
so did they measure the bore after cutting it and could there be multiple sizes on the same block? Only found one B on each side.
doesn't really matter since the block has been bored .030 over
Old Jan 31, 2022 | 03:02 PM
I think they used the same mill on finishing all 8, so they would be the same, nominally.
fly1
May 2, 2023 06:15 AM
virtualwsp
Jan 23, 2022 12:52 PM
wpgjetfan
Jun 22, 2021 07:42 PM
brandon reynolds
Jun 10, 2020 04:39 PM
virtualwsp
Nov 24, 2019 09:44 AM
