Stainless Thermostat Housing Bolts
Old Sep 24, 2023 | 08:07 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
I'm looking to get some stainless arp bolts for the thermostat housing, is the Pontiac bolts the same size as olds? or anybody have a lead on some nice stainless bolts I can use thanks.
Here is the Pontiac set:
https://www.summitracing.com/parts/arp-490-7402
Old Sep 24, 2023 | 08:13 AM
I don't know what might be available north of the border, but here in the US my local Tractor Supply sells stainless fasteners by the pound. This is not exactly a highly-stressed structural joint. I doubt you need to pay ARP prices. On some manifolds, these holes are open to the coolant passage on the bottom, so use anti-seize. The gasket will prevent leakage, so you don't need teflon paste on the threads.
Old Sep 24, 2023 | 08:30 AM
skyhigh's Avatar
Its dosent have to be ARP but they make good stuff, do you happen to no the size of bolt to track down at tsc? and this will be going on my rpm intake thanks.
Old Sep 24, 2023 | 08:45 AM
I believe they are 5/16-18.
Old Sep 24, 2023 | 09:34 AM
skyhigh's Avatar
Thanks alot Joe I had a pack of ARP bolts for something I bought, they didnt work out, think it was going to be for my perfect launch diff cover, but they are the size you mentioned, I guess I will use those.
Old Sep 24, 2023 | 09:42 AM
Good idea. I reinstalled a thermostat and a new thermostat housing gasket yesterday. The bolts were pretty nasty looking even though I had cleaned them recently.👍
Old Sep 24, 2023 | 05:41 PM
oldolds88's Avatar
why not use studs in place of the bolts. i do
Old Sep 25, 2023 | 01:44 AM
skyhigh's Avatar
that's a good idea, but I have the bolts on hand
Old Sep 25, 2023 | 02:15 PM
oldolds88's Avatar
cut the heads off
Old Sep 25, 2023 | 04:10 PM
Those ARP bolts are bad@$$. Make sure you show us an after pic.
Old Sep 25, 2023 | 04:41 PM
442man$'s Avatar
Make sure you have enough length into manifold as to not pull threads out.Those bolts look short.
Old Sep 26, 2023 | 11:35 AM
skyhigh's Avatar
Your sir are correct, so I guess I will have to get longer bolts or studs.
Will22
Jan 30, 2020 07:44 AM
waycoolgreen
Dec 28, 2014 06:28 PM
pmathews
Nov 13, 2014 05:25 AM
deejai35
Jul 30, 2012 05:45 PM
Robert Kiedrowski
Jun 19, 2011 09:20 AM
