sputtering after turning key off
couple times in the last few weeks, my 72 442 with a 350 4bbl has sputtered for a second or two after I turned the key off. Today, it actually sputtered for about 4 seconds and then a puff of smoke came out from under the hood!!!!!
I looked under the hood but couldn't tell where the smoke came from. What should I do??
Any advice would be greatly appreciated. Thanks.
It's dieseling.
Lots of things can cause it, including too high an idle setting, non-functioning or missing anti-dieseling solenoid (it it had one originally), too hot an engine, carbon build-up in the combustion chamber, etc.
You can go over all this stuff and will probably find the cause, but until then, just shut it down in gear and it won't do that. (Though I did have a '68 Merc. Colony Park wagon once with a high-comp. 390, that I could drive down the block with the ignition switch off - you wannna talk about nasty acrid exhaust fumes...).
Oh - the smoke is blow-back through the carburetor.
edit: Rob, you beat me to it by seconds...
It's dieseling.
Not sure how to check the following though:
-Missing/non-functioning antideiseling solenoid;
-carbon build up in combustion chamber;
Location: from Wisc, then Texas, then Kansas, now back to Texas,
get one of them anti- deisel solenoids, or what I call them : the fast idle solenoid they use for AC. Key on, they hold the idle up (put ot at 6 or 700 or whatever), the when you turn the key off it drops to something really where it can't idle
Check for vacuum leaks - they will cause a lean mixture.
I do not think this car came with an anti-diesel solenoid, so I would not worry about trying to install one. Best to find the real problem and solve it.
I would start with RPM, timing, and temperature. Since it started in high temps, I would start looking at the engine temp. Bad fan clutch or undersized radiator could be issues.
To check carbon buildup (last check), pull a few plugs out and look at the piston tops with a good flashlight. If you see more carbon than metal, there may be too much in there. Report back what the plugs look like - that will tell you something.
Check your Chassis Service Manual to see of your engine was originally equipped with an anti-dieseling solenoid.
If it was, then you may be able to get one from a junkyard or a fellow member. If your engine or carb is highly modified, you'll have to use your imagination and judgement.
As for carbon deposits (which can get hot and cause preignition), you can't tell without pulling the heads, but you can clean or replace your spark plugs if they look like they have any crud on them.
Also, do you gave a temperature gauge?
If the motor was unusually hot, that would explain it.
86ChebbyWagon307
July 5th, 2011 07:09 PM
JMW803
May 13th, 2010 04:43 PM
Kidcutty
February 11th, 2010 06:52 PM
