Speed/RPM
Old Nov 8, 2018 | 12:39 PM
LomitaToHamburg's Avatar
Speed/RPM
Speed/RPM
Hi 👋 I’m new here!
I hope my following question is not too trivial:
Short Info: 1966/67 CS 442 400cui -3gear automatic - 120.000 miles - Edelbrock Carb, new headgasket - good compression.
My first American V8! A Dream Come true! But new territory for me:
I‘ve been driving for three hours on the interstate today. It felt like the car was most comfortable at around 55-60mph at ~1.500rpm(if the gauge is right)
My Question is: what maximum speeds or rpm would you guys recommend for this kind of engine (age/ mileage). I don’t want to compete on the left lane, but I’m wondering if I should really rev it up from time to time(of course when engine warm etc) for the engines sake(the official max speed for the car is said to be ~125mph) or if I should just leave it and never go over 80mph?
Thanks a lot !
Moe
Old Nov 8, 2018 | 01:17 PM
Here in the states 80 MPH is about as fast as you can legally go on the highway (75 MPH posted speed limit), so most folks would not be cruising above that speed on a regular basis.
At one point my car had short rear tires, which along with the 3.23:1 rear gears put the engine at ~3200 RPM on the highway (~70 MPH). I had no issues with cruising at that engine speed for several hours at a time.
Old Nov 8, 2018 | 02:10 PM
rustyroger's Avatar
'87 Delta 88 Royale
Does the car have a temperature gauge?. I suggest you keep an eye on it for any prolonged driving at the speed limit. BTW last time I was there a good part of I10 in west Texas had an 80mph limit.
It's far from unknown for older cars to have a partially plugged radiator, you do't need to find yours has after the engine has been cooked.
Having said that if the drivetrain is in good shape and your tires are good then the engine won't be at all strained at highway speeds.
Roger.
Old Nov 8, 2018 | 07:57 PM
I don't think your tach is right, 1500 is a bit low. Should be in the mid'ish 2k.
Old Nov 8, 2018 | 11:37 PM
Levellord's Avatar
Recognizing your license plate you seem to be in Germany.
There was a similar question from another member who wanted to go (for a longer time) as fast as possible on the Autobahn, maybe this helps:
https://classicoldsmobile.com/forums...light=autobahn
If I am with my Cutlass on the Autobahn I always cruise on the right lane with ~120km/h @ approx. 2.700rpm. Relaxing. And if you have to overtake fast a truck there is enough power left, going a few seconds with higher rpm won´t damage anything unless everything is already in a very bad condition.
Old Nov 9, 2018 | 02:43 AM
Yes, that makes sense. ~600rpm in neutral made me scratch my head in the first place...
So, I‘m gonna post the next question how to measure/ fix the rev counter(rally pack) in a new thread?
Old Nov 9, 2018 | 03:04 AM
Fun71, rustyroger and levellord; thank you for your answers/ ideas so far!!
Yes, with Interstate I meant Autobahn - I just wasn’t sure how many would be able to relate and also thought there weren’t any Germans here
But I really love the original setup and want to keep it that way(although interesting info about the overdrive trans). The Car just drives and feels ridiculously beautiful on lower speeds (40-50) so at the moment I wouldn’t want to change that.
Greetings
Moe
Old Nov 9, 2018 | 05:20 AM
You don't want to beat down the road for an hour at 120 mph, but the car should be able to do 100 mph easily for a few minutes at a time. Brakes and suspension must be in correct working order. The standard gear for that car in the differential is 3.08 to 1, which results in @2800 rpm at 70mph. The car should have no issues at all at that speed forever, and should have no issues other than maybe a little heat at 80 mph for extended times. 90 and watch your gauges is ok too.
The factory ralley pac is fun, but aren't very accurate. You may need additional gauges. As long as you have oil pressure and are not overheating, you are ok.
Old Nov 9, 2018 | 06:30 AM
Thanks a lot for the advice 👍🏼
Old Nov 9, 2018 | 06:36 AM
Levellord's Avatar
Moe, couple of Germans here and quiete a lot Europeans.
Congrats you found the way to classicoldsmobile, whenever an oldsmobile problem cant be solved here its unsolvable.
Old Nov 9, 2018 | 12:16 PM
Thanks for the advice 👍🏼
Old Nov 11, 2018 | 12:20 PM
rustyroger's Avatar
'87 Delta 88 Royale
Levelord referred to cruising at 120kph, about 80 mph. If the OP wants to go much faster he needs to be sure the cars is in good shape with correctly inflated tires, and keep an eye on both the temperature and fuel gauges.
Roger.
Old Nov 11, 2018 | 03:30 PM
I would think if you geared the car to put the engine speed at its sweet spot (at whatever vehicle speed you want) as long as the tires, suspension, and cooling system is good for the speed you could cruise at 100plus all day.
Olds offered a 3.91 axle ratio from the factory, no way they would have done that if it would have resulted in warranty issues. If you wanted a gear that steep, other options were required (heavy duty cooling for example). Take a car equipped with 3.91 on the interstate, the engine is going to be spinning pretty fast. Now swap in a 2.56 gear, the car is going to be going much faster at the same engine speed. All things being equal, no harder on the engine than the 3.91. Assuming the engine has the torque to push the car at those speeds the engine doesn’t care what rear ratio you have.
The other option would would be a overdrive trans. Gear the rearend to put the engine in it’s sweet spot at the desired cruising speed with the converter locked and in overdrive. A trans cooler would be a good idea.
cutlassefi
Jun 19, 2017 04:42 AM
willypsilon
Jun 25, 2015 07:36 AM
teacherofphysics
Apr 19, 2011 07:10 AM
Seff
Mar 10, 2011 03:05 PM
442much
Mar 14, 2010 12:53 PM
