Source for 7/8 20 drain plug?
Old Oct 13, 2018 | 04:03 AM
Levellord's Avatar
Hello Gents,
just changed the oil the first time in my (replaced) engine.
Was surprised by the drain plug, not a standard one, seems my pan is from 64/65, according to supercars unlimited.
http://www.supercarsunlimited.com/in...ns/oilpans.htm
No chance for me to get it on this side of the ocean, even a look in your known onlineshops didnt help.
Someone an idea where to get it?
For now I reused the old one, but I am not to happy with this.
Thx and Regards,
Marc
Old Oct 14, 2018 | 01:17 AM
Levellord's Avatar
Oha. Silence here is never good. Guess I‘ll have to make a metric thread in the pan.
Old Oct 14, 2018 | 01:35 AM
svnt442's Avatar
Have you tried going to the parts store?
Old Oct 14, 2018 | 03:06 AM
Levellord's Avatar
I am in Germany, I get in every shop M1-50 thread size, american system is quiete rare.....and 7/8 20 seems to be even in US not a common size.
Old Oct 14, 2018 | 03:23 AM
dragline's Avatar
Marc, you certainly stumped the board. Searching the net only turns up the tap. Going metric may be your only choice, or changing the pan. I hope you have success with your car. Viel gluck! This is the closest I could find.
https://www.dormanproducts.com/p-153...origin=keyword
Old Oct 14, 2018 | 04:01 AM
35tac's Avatar
Just a thought. Approach a local machine shop. A replacement plug or two could be made. Plugs don't seem to be complicated if you have the original as a sample.
Wayne
Old Oct 14, 2018 | 05:40 AM
edzolz's Avatar
I had the same problem and used the above drain plug from the referenced source. Works great, not original looking but works.
Old Oct 14, 2018 | 08:56 AM
Mr Shifty Sidney's Avatar
https://www.summitracing.com/parts/fra-491980-bl?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-fragola-performance-systems&gclid=EAIaIQobChMIpNfI7qCG3gIVglcNCh0Abw2o EAQYASABEgIif_D_BwE
I searched Google for 7/8 -20 pipe plug and got the above results from Sumitt Racing. Note it is aluminim.
Are the threads on your plug stripped or is the square hole that is used to tighten the plug stripped?
Don W
Old Oct 14, 2018 | 09:31 AM
edzolz's Avatar
Don W
The Dorman product is steel.
Old Oct 14, 2018 | 09:54 AM
Question is, are we SURE that the original is 7/8-20? That is not a standard type thread.
Once we figure out what he has, we can do shipping easily. If he can't get it, we can just mail him a couple. It's a bolt, to keep our friend on the road. Easy enough.
Old Oct 19, 2018 | 01:41 AM
Levellord's Avatar
Thanks my friends, was a few days offline. For now the old screw Is in AND not leaky so I move this problem to next year and next oil change...then I will check if its really 7/8 20 and ask again for your help. Thx!
Old Oct 19, 2018 | 05:58 AM
edzolz's Avatar
Any machinist knows that a 7/8-20 thread is a standard UNEF (extra fine) thread designation. So, Yes it is a standard thread size. Not a normal off the shelf item, but a standard thread. And that is what I used in my Olds pan. Fit perfectly.
Scheil442
Feb 2, 2019 08:04 AM
Fpcopo
Jan 8, 2019 03:28 AM
plonka
Jan 24, 2015 10:47 AM
onetogofast
Oct 12, 2014 07:27 PM
Olds64
Feb 17, 2009 01:20 PM
