Sound deadener
Old Oct 7, 2023 | 02:12 PM
tkcutlass's Avatar
Sound deadener
A couple of questions regarding sound deadener.
1. Should any gaps between the sheets on the floor be filled with foil tape to minimize water getting under?
I see some posts showing holes covered and others with all holes cut out.
2. Will I get vibrations from covered holes defeating the whole concept of sound deadening?
In particular, the seat divider has several holes.
Old Oct 8, 2023 | 07:07 AM
VC455's Avatar
Barely Registered
That type of deadener reduces panel vibration.
Only about 60% of the panel needs to be covered to do this.
But I covered everything as you did. I taped the joints to keep it waterproof.
Old Oct 8, 2023 | 11:35 AM
Oldsguy's Avatar
Past Administrator
Seems to me that every little bit helps. These new products are light years better than the original rubberized paper stuff that came on the cars. I plan on doing this to my project when the time comes.
Old Oct 9, 2023 | 12:49 AM
cfair's Avatar
I slathered my floor pan with no gaps from trunk end to firewall up under the dash. No gaps. It works, but I do worry a little about trapping water underneath.
The 60% rule is a good one. I went overboard, just because I could. But I was happy with the result
It was good enough on the floor pan that I eventually did the roof of my ‘66 Starfire (hardtop coupe) between the steel roof and headliner.
What you learn is that when you have successfully deadened the big noises, the little noises come out.
Simply put, with these materials, noise is eliminated from the floor pan, but now you start hearing wind noise from vent windows and side glass.
Hope I didn’t depress you. I’m a big believer in noise reductions.
Chris
bigrbandit
Aug 5, 2022 09:00 AM
2blu442
Mar 23, 2022 04:59 AM
Burd
Dec 18, 2021 07:09 PM
johnrossjdr
Mar 5, 2018 03:00 PM
kinghenry88
May 15, 2013 06:56 PM
