Sill Plate Resto
Old Sep 15, 2016 | 08:48 PM
Magna86's Avatar
Sill Plate Resto
Has anyone cleaned up and refurbished their original sill plates? The ones on my 66 are in good shape just/oxidized obviously after 40+ years. Whats tips or tricks do you guys have? Wet sanding won't get down into the ribs to even out the appearance compared to edges.
Old Sep 15, 2016 | 09:07 PM
What about a small buffing wheel on a die grinder or drill?
Old Sep 16, 2016 | 10:37 AM
Run to Rund's Avatar
The problem will be to get the original texture/finish which is not a high polish such as would probably result from a buffing process. I have some good used and some NOS ones, BTW.
Old Sep 16, 2016 | 12:26 PM
76olds's Avatar
Hookers under Hood
A fine scotch brite pad will bring it up nicely. You'll go through a few pads in the ribs. Then buff with the pad Oldcutlass pictured.
Eric
Old Sep 16, 2016 | 04:08 PM
Magna86's Avatar
I'm not worried about the correct finish as this car is nothing valuable so if I can get a polished look that will be fine.
Old Sep 16, 2016 | 04:16 PM
cdrod's Avatar
Rodney
Fine-grade steel wool would work well for this task, and it comes in various grades from coarse #3 to extra-fine #0000.
Old Sep 16, 2016 | 06:17 PM
Tedd Thompson's Avatar
I know little about a 66 but on a 55 you can remove the sill and have it buffed by a trim shop.I'm sure that the finish could be restored by a decent operator... Tedd
Old Sep 18, 2016 | 05:58 PM
Magna86's Avatar
Thanks for the tips. Hopefully I'll get to work on them before I head out of town again for work and can get some decent results.
K-Dog
Apr 11, 2015 07:09 AM
JackJack56Olds
Jun 24, 2013 05:19 AM
at3reg98
Jun 24, 2012 10:10 AM
gearheads78
Jul 23, 2009 10:26 AM
Bluevista
Vista Cruiser & Wagons
Nov 8, 2008 05:12 PM
