Should I replace my fuel sending unit?
Old Aug 24, 2015 | 07:57 AM
Christophe2m6's Avatar
Hi guys!!
Going to repaint my fuel tank, and btw, also replacing the fuel sending unit cable that works when it wants to...
As I will drop the tank off, and also remove the fuel sending unit, do you think I should also replace it?
It still works fine, but is 45 years old, full of sludge and rotten...
Found some on eBay for 60$ shipped (to France).
Imo, would replace it as I will have the tank down...
Thanks for your advices!
Old Aug 24, 2015 | 08:02 AM
If its all corroded and sludged up, I would probably change it since the tank is out. It would suck to have to drop the tank again later.
Old Aug 24, 2015 | 12:27 PM
Thanks a lot for your answer Eric!
I found that the sending unit uses 3/8 hose.
Is it the internal or external diameter of the hose?
Thanks again!
Old Aug 24, 2015 | 02:41 PM
toymobile's Avatar
Originally Posted by christophe2m6
thanks a lot for your answer eric!
i found that the sending unit uses 3/8 hose.
Thanks again!
3/8 id
Oldskool84
Oct 10, 2014 06:21 AM
pfergy600
Oct 4, 2014 05:29 PM
billreidjr
Oct 8, 2008 06:29 AM
Pfiffle
Feb 21, 2008 06:43 PM
