Separate a rear view mirror
Old Mar 24, 2013 | 04:04 PM
keverson's Avatar
My 70 Cutlass has a metal rear view mirror that appears to be crimped together. I need to take the glass out and have it re-silvered. Anyone know how to take these apart? Thanks!!
Old Mar 25, 2013 | 10:25 AM
455man's Avatar
There are a few posts in here on how to attempt it. It's pretty tough and I gave up on my mirror. Just found a better one at a salvage yard.
Old Mar 25, 2013 | 11:21 AM
Texas69's Avatar
The glass is held in by light glue on the backside And by the rubber seal around the edge. Dip the mirror in hot water or use a hair dryer to warm up the rubber lip and glue. Use a butter knife or other object to gently go around the perimeter and separate the glass from the rubber. Try to get behind the glass to pry it up. The edge of the glass may chip if you pry from the side. Patience is key, and you may have to reapply the heat a few times
Old Mar 25, 2013 | 04:59 PM
keverson's Avatar
I didn't realize there was a rubber edge until I took the mirror off. I thought it was metal. The heat idea worked great. I used a heat gun to soften the rubber edge enough to bend it back. Then used a putty knife to get behind it and gently push it down to release from the glue. I'm sending it out tomorrow to get resilvered. Thanks for the replies!
stevengerard
Dec 31, 2009 04:01 AM
roy341
Jul 11, 2009 05:27 PM
tim72
Apr 9, 2009 05:33 AM
64 Olds Dynamic 88
Apr 27, 2008 06:53 PM
<diablo76delta88>
Sep 11, 2003 08:41 PM
