Valvetrain Change
Old Mar 20, 2013 | 11:58 AM
rcrac3r's Avatar
Valvetrain Change
My 72' 350 rocket is getting a full rebuild & I want to change out the rocker "pivots" and install adjustable rocker arms. I know the arms will need studs, guide plates, etc. Anyone done this? I've been looking on the Comp Cams site & I think I've found all the parts but I'm not sure what size the studs need to be.
Old Mar 25, 2013 | 12:11 PM
rcrac3r's Avatar
Wow crickets on this one. Has anyone swapped out those pivots for adjustable rocker arms?
Old Mar 25, 2013 | 02:08 PM
Lots of people have. What do you want? The available conversions range from bolt-on (Harlan Sharp shaft-mounted and Comp Cams with the special 5/16" studs) to those that require machining to install real studs (3/8" or 7/16") and guide plates.
Old Mar 25, 2013 | 02:29 PM
DENT's Avatar
I just installed the comp cam studs and guide plates with roller tip rockers. I have not run the engine yet so i can't say how i like it. Let you know later.
Old Mar 25, 2013 | 03:03 PM
DeltaPace77's Avatar
I've done just that, with an adjustible valvetrain kit I got from from Dave Smith Olds. I also got the custom heads from Dave, that already had the studs installed. Valves set up just like a SB Chevy, and only way to go.
Old Mar 25, 2013 | 04:35 PM
krooser's Avatar
Hot Rod Has Been
I just did the same on my circle track 330... I also milled down the pedestals the thickness of the guide plate to keep the valve train geometry correct and I enlarged the pushrod holes in the head to 9/16".
Old Mar 25, 2013 | 06:08 PM
bccan's Avatar
Consider the Harland Sharp shaft mount rockers, they are a sweet setup. If you are willing or can justify spending about twice as much money to have a true roller rocker setup. No guideplates needed, may need pushrods either way.
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
70cutty
Aug 15, 2008 09:45 PM
SPEEDROCKET
Dec 18, 2007 05:58 PM
davy5
Apr 24, 2007 10:00 AM
