Schneider cam
Old Jun 9, 2013 | 03:36 PM
Tom442's Avatar
Schneider cam
My neighbor has a cam he wants to sell. He got it years ago for a boat he had with a Big block Olds. I was wondering what kind of application this cam would be good for? Here are the specs
EDIT.....Schneiders website shows this grind and the specs below for International Harvester? Hmmm I don't have a combine or planter right now...
Part Number: 15100
Grind Number: 131H
Intake Duration (gross): 262
Exhaust Duration (gross): 262
Intake Duration (.050”): 208
Exhaust Duration (.050”): 208
Intake Valve Lift*: .464"
Exhaust Valve Lift*: .468"
Lobe Separation: 112
Intake Valve Lash: .000"
Exhaust Valve Lash: .000"
RPM Range:
1800-4800
*Based on 1.6 int / 1.7 exh Rocker Arm Ratio
Thanks for any and all input.
Tom
Last edited by Tom442; Jun 9, 2013 at 03:42 PM. Reason: New info has come to light
Old Jun 9, 2013 | 03:52 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Nice cam for a low compression 350, how much does he want.
Old Jun 10, 2013 | 08:35 PM
Tom442's Avatar
Failing memories
So I asked my neighbor for more info om the cam. He can't remember what the story is. He thinks now that the cam in the box was replaced by the Schneider cam into his jet boat. He thinks a he replaced the then existing cam with the Schneider as it was more radical. So here is a pic of the cam..anyone recognize the stampings?
Tom
Old Jun 11, 2013 | 02:09 PM
BlackGold's Avatar
I'm guessing that the "CD" stands for Cam Dynamics, an older company which was purchased by Crane. The "240H" probably refers to a lobe profile with 240 deg duration (at .050) for use with Hydraulic lifters. The "U332" might refer to a specific part number or application. Or it might be the blank before grinding. Crane can probably tell you.
Old Jun 11, 2013 | 06:13 PM
copper128's Avatar
Lt. Buzzkill (ret.)
BlackGold is correct.
That's a very mild hydraulic street cam best suited to a low compression engine.
Old Jun 12, 2013 | 04:00 PM
BlackGold's Avatar
Just to be clear, a 240 duration lobe (at .050) isn't exactly mild. But the cam in the original post (208 duration at .050) certainly is mild.
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
1964droptop
Nov 17, 2009 11:03 AM
Rocketman
Nov 22, 2004 01:59 PM
