Scarebird Master??? 1962
Old Mar 4, 2010 | 12:14 PM
Natas's Avatar
I was just wondering if anyone has done the Scarebird disc conversion. I have bought a 4-wheel kit and it seams self explanitory. I'm just in a loss for what mastercylinder to run. It's going on a 62. Any help would be great.
Old Mar 4, 2010 | 05:28 PM
citcapp's Avatar
I have done the scarebird disc conversion on both the front and the rear of my 57 Olds. The installation was pretty straight foward.
I am not familiar with the 62, Don you have power brakes? Is the power brake booster and master cylinder fire wall mounted ? Can you take a picture of you current set up. Maybe I can help you out if I see what you have.
Old Mar 5, 2010 | 07:14 AM
Natas's Avatar
Here is what I have. Fruit jar.
Old Mar 5, 2010 | 07:28 AM
citcapp's Avatar
I would think that if you take the master cylinder wih you to a good NAPA or othe auto store you could match the throw of the piston of the master cylinder with a dual master set up. The GM bolt pattern should be the same. You just need a good counter man to help you out. If you're only putting disc brakes on the fromt make sure you get a combo disc/drum master. If you're puting disc's all around then get a disc/disc set up. also purchase a perportioning valve as well. Good luck
Old Mar 5, 2010 | 12:08 PM
KQQLCAT's Avatar
I think that 67 Olds is what your looking for. Dual resivoir with disc brakes.
KQQLCAT
Brakes/Hydraulic Systems
21
Nov 17, 2020 05:37 AM
keepitolds
Feb 3, 2013 09:09 AM
eddieunderground
Jan 16, 2011 07:39 AM
66ninetyeightls
Apr 20, 2010 07:54 AM
68droptop
Mar 31, 2009 06:10 PM
