My Scarebird Disc Brakes
Old Mar 27, 2014 | 03:26 PM
KQQLCAT's Avatar
Here's a couple of pictures of my install. I didn't go in depth because there is another one that does that.
Old Mar 27, 2014 | 03:42 PM
don71's Avatar
same but different
Thanks for adding those photos . You know some of us have no idea how to make things work on these earlier models. We're all ways learning.
Show us a link to what else you've been doing with your ride. I've probably seen it, but others might not.
Old Mar 28, 2014 | 09:26 AM
Don R.'s Avatar
Good looking job. Did you use the Scarebird #OLD kit? I posted elsewhere about possibly using that on a 63 Starfire:
https://classicoldsmobile.com/forums...onversion.html
Did everything bolt up and fit right? Did you have any trouble finding the parts recommended on their list?
Can you list a source and part number for the master cylinder and proportioning valve? Did you use your booster or did you replace with a new style?
Thanks for any help you can provide.
Old Mar 29, 2014 | 07:48 AM
D. Yaros's Avatar
And what size wheels went on the car after the conversion?
Old Mar 29, 2014 | 09:10 AM
Rocketguy's Avatar
What size are those rotors?
Are you going to use any water shields?
Old Mar 29, 2014 | 02:04 PM
KQQLCAT's Avatar
Yes it was the OLD Number 61-64 The only problem I ran into was I powder coated my spindles and had to remove some powder coating wher it bolts at the top. I purchased all the parts at Rock Auto real easy.
Booster is a 67 Olds for disc/ drum
The master was purchased on eBay: http://www.ebay.com/itm/4-PORT-CORVE...8ff88a&vxp=mtr
Old Mar 29, 2014 | 02:07 PM
KQQLCAT's Avatar
These are directional and 11.5" No shields are needed for limited use.
Old Mar 30, 2014 | 08:14 AM
D. Yaros's Avatar
I am still interested in learning WHAT SIZE WHEELS after the conversion?
Old Mar 30, 2014 | 08:35 AM
Don R.'s Avatar
Thanks, very helpful. Where did you find that booster?
Old Mar 30, 2014 | 08:39 AM
Don R.'s Avatar
Not necessary. All the 94 to 96 Chevy Caprice 9C1 police cars had heavy duty discs with the water shields left off at the factory to improve cooling. I drove one for four years with no problem at all.
Old Apr 1, 2014 | 09:51 AM
KQQLCAT's Avatar
I used 17x7 in front and 18x8 in rear.
Originally Posted by d. Yaros
i am still interested in learning what size wheels after the conversion?
Old Apr 1, 2014 | 09:56 AM
KQQLCAT's Avatar
Bought it at Rock auto.
1967 Oldsmobile Delta 88 A-1 CARDONE Part # 5473115
Old Apr 1, 2014 | 11:59 AM
Oldskeeper's Avatar
I'm thinking of adding this to my 62 super wagon, will crager 31 spoke 15 inch rims fit over?
The set up looks good on your car, how is the stopping power in relation to the drums?
Steve
Old Apr 1, 2014 | 01:43 PM
KQQLCAT's Avatar
I can't answer that yet it is still winter here and haven't taken out yet.
Steve
Old Apr 1, 2014 | 01:56 PM
Oldskeeper's Avatar
that's OK it's still winter here too!
I have about a foot of snow still on the ground and a few drifts of snow along the fence line.
Old Apr 4, 2014 | 09:40 AM
KQQLCAT's Avatar
Just got another foot of snow. Getting tired of this winter!
Old Apr 4, 2014 | 02:20 PM
Oldskeeper's Avatar
We are under a weather advisory now for freezing rain and flooding as the snow is melting fast.
COME ON SPRING!!!!
I need to get my 98 out and clean the cob webs of winter out of her and go get a burger.
lets hope this is the beginning of spring, been a long cold winter up here.
Old May 6, 2014 | 12:29 PM
KQQLCAT's Avatar
Finally got the car out of the garage to test the brakes and the brakes stop quite a bit better than before. Very happy I spent the money to do this.
Steve
Old Mar 23, 2016 | 06:36 PM
Higgins's Avatar
Distribution Block
I started researching for Disc brake conversion for my 63 Starfire and came across your thread. Very helpful, thanks for posting it. I have two question,if you could tell me what you did about the distribution block and did you need a metering block or did the new proportioning valve eliminate those? The description indicates it does but I just wanted to double check. Also, did you have to change the original booster or could you have used the original one?
Old Aug 27, 2020 | 05:55 PM
nightmare's Avatar
What backspacing did you use on the 18x8s? I tried to use som 16x8s but they were extending past my rear fenders
Old Aug 28, 2020 | 08:09 AM
Tedd Thompson's Avatar
This is a very old thread if you don't get a response try a PM to the original poster....Tedd
Old Nov 17, 2020 | 05:37 AM
KQQLCAT's Avatar
4.5"
keepitolds
Brakes/Hydraulic Systems
Feb 3, 2013 09:09 AM
russell-t
Apr 30, 2011 05:56 AM
66ninetyeightls
Apr 20, 2010 07:54 AM
Natas
Mar 5, 2010 12:08 PM
68droptop
Mar 31, 2009 06:10 PM
