Rust Remover
Old Feb 12, 2009 | 12:16 PM
fatboy578's Avatar
Rust Remover
Does anyone know or ever used a rust remover that actually works? One that you can brush on and rinse off,I have see many advertised,but would like one that actually works very well. I would really appreciate any feedback. Thanks Larry
Old Feb 12, 2009 | 12:54 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I haven't found any that are worth the money and effort yet.
I've found there's no substitute for a good sandblasting.
My advice is: Save your money, and have it done up right.
Old Feb 12, 2009 | 12:56 PM
68Tom's Avatar
Depends on what level of rust you're taking about. If you have sanded off almost all of the rust and have traces left, I'm pretty sure Rust Free does a good job of converting remaining rust.
http://www.theruststore.com/Rust-Rem...art-W22C2.aspx
If you aren't sanding anything, I don't think there's anyting you can brush on and rinse off that's going to do a perfect job. That will require soaking or a continual "rinse". Check this out....
http://www.missbelvedere.com/
Maybe other's have some other experience with some products that you're looking for.
Old Feb 12, 2009 | 05:05 PM
Tom is right on. If you have already sanded and done grinding on the rust then rust remover is a good idea to get all of the little bits of rust chemically neutralized. If you don't plan on sanding first then don't bother with the rust remover.
Old Feb 12, 2009 | 06:32 PM
a64olz's Avatar
rust remover
For parts try this, about $7 for rebar, $5 for walmart container, and about $3 for arm & hammer washing soda, about an hour of build time and a 8 hour soak in the tank, the charger is set at 12 volts 2 amps google elecrolytic or electrolysis rust removal it works.
Old Feb 13, 2009 | 04:28 AM
That is a cool idea!
Old Feb 13, 2009 | 08:00 AM
citcapp's Avatar
a64olz
Thats neat, Thanks for sharing this with the rest of us.
Old Apr 17, 2011 | 07:26 PM
70442rag's Avatar
For every gallon of water how much baking soda do I put into the tub?
Thanks!
Brad
Old Apr 17, 2011 | 07:31 PM
442much's Avatar
I think it's washing soda, not baking soda...or maybe baking soda in a pinch?
hawks70
Paint
Oct 4, 2013 02:47 AM
carl 87 cutlass
Nov 1, 2012 05:42 PM
Stevec
Feb 9, 2012 04:42 AM
69cutdawg
Paint
May 17, 2011 02:53 PM
tim72
Drivetrain/Differentials
Apr 3, 2009 09:00 AM
