Rochester Quadrajet question
Old Feb 24, 2013 | 11:42 AM
rocketman77's Avatar
I pulled a Rochester QJ from a 1966 Starfire sitting at the junkyard the other day.
it has a code 7032720 cast in the assembly.
Does anyone know if this QJ number was only unique to Oldsmobile? Only to Starfire? Good for any other cars? I might keep it but not sure if I want to pad my wallet instead if it is worth anything.
I saw another thread on here where someone thought it was also used on the Toronado.
Old Feb 24, 2013 | 11:54 AM
Octania's Avatar
That's the body casting number, from which any of numerous similar carbs can be made.
Look for the ~3/4" round TAG pressed into the SIDE of the carb, LH side, above the front throttle shaft.
"7036254" or similar will be stamped into here.
Factory '66 Qjets had a link up over the LH secondary air valve, for a piston based damper for the secondary air valve. Abandoned after 1966, it was presumably a suboptimal solution.
Hawk1061
Apr 1, 2014 07:14 PM
BB Blue 67
Sep 13, 2011 01:45 PM
kandelino
Nov 25, 2010 02:53 PM
yeahbuddy
Sep 20, 2010 06:21 PM
sanemb
May 28, 2008 05:43 PM
