On the road need help
Old Jun 13, 2012 | 06:34 PM
White Spyder's Avatar
Just picked up my new 75 Delta 88 and the left brake hose needs to be replaced before I hit the road for a trip home. Question is on the driver side where the rubber hose connects to the hard line there seems to be a special nut. Or do you loose the nut on the hard line side of the bracket
TIA
Old Jun 13, 2012 | 08:06 PM
Found it in the manual on crazy about cars. What a PIA. It does loosen from the hard line side. Then you have to move the line to the side to remove the bracket to get the hose out.
Now to find a hose in the morning and get on the road.
Old Jun 13, 2012 | 08:23 PM
Lady72nRob71's Avatar
Looks like you got it. Make sure to use a special line wrench on it so you do not round off the nut. If that happens, you are in deep crap. A line wrench and some taps with a rubber mallet should free it.
If possible you should change the other one, too. It will be as old and then you bleed brakes one time.
Glad you are replacing them now before they become a hazard later.
Old Jun 13, 2012 | 08:48 PM
Glad you got that ok. The fitting you're describing is called a 'flare nut'. It's the part that's supposed to turn so you can remove the hose. USE BOX END WRENCHES to loosen and tighten. You need 2 different sizes (can't remember what size right now). Be careful with the banjo bolt to the caliper and make sure you don't forget the crush washer.
You prolly know this, but just to be safe I'm going to say it. You need to BLEED THE BRAKES after you complete this repair.
Old Jun 13, 2012 | 08:53 PM
Rickman48's Avatar
And when you get home, do the other one - they are the same age!
Old Jun 14, 2012 | 01:46 AM
THanks all will be changing all the others when I get it home and in the shop.
Old Jun 14, 2012 | 12:13 PM
Prolly would be a good idea to check the pads, rear brakes shoes, springs etc. Hope your ride back was super. Hopefully with the top down? Yahoo!
GoodOldsGuy
Dec 13, 2013 12:10 AM
Cjs1969
Aug 1, 2013 07:09 PM
69olds442
May 29, 2011 06:11 PM
Oldskool88
Feb 16, 2008 01:46 PM
