Restoring carb tags?
![](https://cimg5.ibsrv.net/gimg/classicoldsmobile.com-vbulletin/960x540/86480853_2804034119717417_9176899867941797888_n_a4014f733883e56ae7641405a77c427310e85a1f.jpg)
I am very thankful for the member that came forward and provided me with these original carb tags for my freshly restored carbs.
I'm unsure if I'm going to use them as is or attempt to restore them.
Looking for advice or tips.
Do you think I'll be able to very gently slightly straighten them without making the small crack in the bends worse?
Were these originally anodized or painted? I'm thinking painted because only one side shows signs of having color.
So,if you were going to attempt to restore them,how would you straighten and recolor them?
thank you
I agree, get them warm, not hot, maybe use like wooden chopsticks , you could file each chopstick to a larger or smaller diameter flat end and very very gently push the aluminum back into shape being careful not to flatten numbers or the embossing. They would certainly be presentable then. Paint them and put them on. Won’t be perfect but acceptable.
In 2020 I bought a set from Mike Seidlik, olds@megavision.com. Mike had had a health issue, but was back on the grid. Send him an e-mail.
lemoldsnut
June 19th, 2016 07:00 PM
