Any TH400 trans experts ?? HELP !
Old Dec 31, 2021 | 10:40 AM
Vader's Avatar
Thanks for everyone's help. Turns out a valve was stuck in the valve body.. arghhh
Old Dec 31, 2021 | 11:41 AM
70W-32's Avatar
Check with Matt (matt69Olds). he's the resident trans expert
Old Dec 31, 2021 | 01:55 PM
Do you have vacuum to the modulator? Also check for power at the kickdown switch.
Old Dec 31, 2021 | 02:21 PM
It will hold it in first gear.
Old Dec 31, 2021 | 02:30 PM
Originally Posted by Vader
Vacuum at mod is approx 15 at idle 22-25 at 2200rpm. How does the kickdown effect the `1-2 upshift ?
Does the shift points change with additional throttle, or is it delayed and firm at every throttle position?
Make sure the vacuum line isn’t kinked, carboned up, or restricted in any way. The modulator needs to react to changes in vacuum pretty quickly.
Pull the modulator valve from the case, it needs to move freely.
Next thing to check is the kickdown solenoid. Disconnect the wire to the solenoid (orange wire at the case). Check for power, it should only show power at WOT. If so, it’s time to drop the pan for inspection. Make sure the solenoid is intact, bolted securely, and has no gasket (assuming it’s the later model square kickdown solenoid WITH a gasket molded to the mounting surface. The early oval can style used a tin steel shim gasket.
Old Jan 1, 2022 | 08:35 AM
I have tried to copy and paste a article here, for some reason it won’t show up. I’ll try to explain as best as I can, a picture is worth a 1000 words!! I wanted to post a couple hydraulic diagrams.
There is a valve setup in the valve body called the detent regulator valve. It takes line pressure and regulates it to 70psi (iirc) that regulated oil works against the 1-2 and 2-3 valves, holding them in the upshift position. The detent (kickdown) solenoid has a valve that is held closed by a spring. At WOT, detent oil is vented from the detent valves. That allows the valves to go into the downshifted position. There is also govenor oil working against the shift valves. When govonor oil goes high enough (the car is going fast enough) govonor oil will overcome the detent oil pressure, allowing the valves to move into a upshift position.
There are 3 different size detent valves in the 1-2 valvetrain. I’m guessing the different sizes were used for cars with wildly different kickdown needs. A car with 3.91 gears would need a lower upshift speed than one with 2.73. Or a high winding W-31 engine could tolerate much higher upshift speeds than a 6.2 Diesel engine.
As for your problem, if you disconnect the vacuum modulator with the engine running, you should notice a very distinctive change in the way the engine idles from the big vacuum leak. If not, the line might restricted.
Is the line mostly steel? Rubber hose can easily get sucked closed, restricting vacuum.
Do the shift point change at all in relation to throttle position? You said it winds out until about 4000, does it shift at 4000 at WOT?
76olds
Jan 9, 2015 02:48 PM
Olds luvr
Aug 12, 2014 08:52 PM
coppercutlass
Aug 4, 2013 07:21 PM
cdoering
Apr 13, 2013 08:05 AM
J-(Chicago)
Oct 2, 2009 12:05 AM
