It was time to replace the 50 year old fabric in the rear window channels of my front doors. My door rear window channels were nicely polished in certain places.
When I did my convertible, all I had around was cotton fabric, which has worked fine for a few years, but with the Starfire I wanted to see if I could do something a little better. I settled on very wide velcro, the fuzzy side.
First you have to get the channel cleaned out of the old stuff. I found that 3M's special adhesive remover worked just great. Except it runs all over the place. To work, it really needs to set for a while to solve/break down the old fabric adhesive. I wound up shoving paper towels into the channel and soak the towels with the 3M adhesive remover. Of course I hit on this after I'd made a good smelly VOC mess on my workbench.
A good way to remove old rear window channel insulation. Use in a ventilated area.
Restoration / reproduction fabric exists, but it's very thin. For replacement I used 2" wide black velcro with a sticky back, using only the fuzzy side to replace the old fabric. It turns out the '66 big car rear U channels are substantially deeper or wider than 2". Good thing I got lots of velcro. I'm hoping velcro will wear longer & create just enough isolation without binding the glass or slider in the channel.
Windows need to slide on a consistent surface through their up/down travel so the replacement liner needs to lie flat.
I used one length of velcro formed into a U shape to line the bottom of the U (aka the rear of the channel). I was pretty sure it would be hard to use the adhesive backing of the velcro getting to sit flat, so I glued these U shapes down with 3M interior spray glue. Then I had a few minutes to slide the velcro U around and get it to sit roughly evenly in the channel.
2" isn't deep enough to really isolate the glass from the metal side walls which might scratch it. I took another length of fuzzy velcro and X-acto sliced it in to 2 X 1" wide lengths to line the sides of the U channel. To install these parts I peeled back about 1" and set it as squarely as possible against the velcro U channel to avoid binding. Then I slowly worked my way down the channel nudging the sticky back velcro into just the right line to match the U that was already there.
It probably would have been better to get much wider velcro, like maybe 4" wide, but this worked. I like the idea that I didn't have to glue the whole thing exactly perfect on the first go.That almost never works for me.
Oh -- when you get this deep into it, it can help with adjusting to clean up all the threads on the special long window nuts, in my car they're 1/4-20.
Not a real fun job, but once you get this deep in, you might as well get it as good as you can.
