Replacing valve cover 67 supreme questions
Old Apr 7, 2012 | 06:40 PM
MudEye's Avatar
Hey Man
Was about to change valve cover gaskets 67 supreme.
There are a few threads,but I had a couple questions.
The argument: cork vs rubber.Cork needs adhesive rubber no(maybe some vaseline to help stick) Any proof or opinion that one is better?
Also I read a thread here that said to clean the valve train gunk out while the covers are off.Besides cleaning the gunk out,would something like "seafoam"
help get the rest out? I don't know,just asking for wisdom here.
Also,I heard an "Old Wive's tale" that you should "never" clean the gunk out of your old engine, because that's what holds it together! And once you clean out the junk then it will fall apart,leak,and go to pot.
Is there even an ounce of truth to this theory? or maybe it's fact! HeHe!
In all seriousness, what is your experience.I just need the proper guidance.
Thanks..............Mudeye
Old Apr 7, 2012 | 07:18 PM
67 Cutlass Freak's Avatar
valve cover gaskets
I like these-
http://www.summitracing.com/parts/FEL-VS50156T/
They are a little pricey, but they seal up well. No adhesive, and they're reusable. As far as the old wives tail: The gunk inside your engine does absolutely nothing for the structural integrity of your engine. However the problem occurs when you disturb the oil/ carbon build up and dislodge it. No doubt some will head toward the oil pan and your pick up tube. Some may even get past your oil filter and end up trashing your bearings. My best advise to you is to block the oil drain back holes while your cleaning. I use a shop vac and a screw driver at the same time to attack the big stuff. You can use brake clean and parts wash but try not to let to much go down to the pan. I also use a stiff bristle wire brush then compressed air to blow it all dry. Make sure the oil drain back holes are totaly clear before you bolt the cover back on. I like to use sea foam in the crankcase to help free up sticky lifters. I always put it in and run the engine at 2000 RPM for a couple minutes, then do a full oil change.
Old Apr 7, 2012 | 07:21 PM
Oldsmaniac's Avatar
I do not use sealer on any type of valve cover gasket. Some of the bolt holes are usually a bit smaller and the bolts can be placed thru and it will hold the cover enough so the other bolts can be inserted without loosing the gasket when positioning. No problem cleaning the covers just dont leave any cleaner or abrasives in there that may end up in the engine. It is an engne type flush that is a no no cause you will stirr up all the crap that has found a harmless resting place and circulate it thru the engine....not good.
Old Apr 8, 2012 | 04:31 PM
jag1886's Avatar
I have always (30 years) siliconed the gasket (cork) to the cover 1/2 hour before install, it works perfect every time and the cover can be removed and reinstalled several times before the gasket is shot. As far as cleaning the inside of the head I always remove everything I can with a rag and engine or carb cleaner and vacuum out all the debris, there is a quit often chunks of carbon or valve seal plastic it the bottom of the head, just be careful not to loose to much down the oil return holes at the ends of the head.
Old Apr 10, 2012 | 05:34 PM
MudEye's Avatar
Filter
I bought the gasket\filter kit. Is the filter relatively easy to change? Never even changed a gasket before(oil change a couple hundred times) So this tranny filter looks extremely unique.About an inch round pipe and maybe 4 " tall on a rather flat plate almost resembling a triangle with a open hole on top.
I put the vehicle up on jack stands.To make it easier.Thanks
Old Apr 10, 2012 | 05:54 PM
MudEye's Avatar
mistake
Lol! sorry Jag , I was talking about the Transmission gasket\filter not valve cover gaskets! But your opinion is still appreciated.
Old Apr 10, 2012 | 06:33 PM
If everything is working well, my personal recommendation would be to NOT clean anything other than the sealing surfaces themselves.
All of that gunk in there isn't hurting anything, and there is no reason to mess with it.
It's one thing to clean everything if you are disassembling and rebuilding the engine, where you will be able to clean out every little nook and cranny, it's a different thing to clean one part and risk mobilizing crud that's in a safe place right now.
Cleaning it may make you feel good, but it may also make the engine feel bad.
Resist the urge to make something nobody ever sees "pretty" for no reason other than your own sense of order.
Old Apr 10, 2012 | 07:15 PM
mike's88's Avatar
Originally Posted by 67 Cutlass Freak
I like these-
Since you mention seafoam,which in my opinion, is a great product, and others say not to wash the gunk into the oilpan, adding seafoam to the oil does basically what the others say NOT to do. Is seafoam good for the oil system or not? I know it works great in gas, but how about oil?
JBrooks
Dec 23, 2022 07:22 AM
navvet
Mar 14, 2015 05:45 PM
zodiacblueS
Brakes/Hydraulic Systems
Jan 4, 2013 09:45 AM
70Cutlass_408
Mar 21, 2011 09:31 PM
dallas6778
Nov 20, 2007 10:04 AM
