Removing Wiper Blades
Old Dec 10, 2018 | 05:37 AM
Destructor's Avatar
How does one remove the stainless steel Trico wiper blades from the wiper arms on a 1970 Cutlass. I know they clip into the grove of the arm but I have yet to figure out how they disengage. I have replacement blades and I do not want to damage the stainless Tricos. I may want to put them back on if I find replacement refills. I need operational wipers for my summer drives when a T storm can sometimes blow through. I am very much mechanically inclined and have done a lot of work on my car on my own but these things have me baffled as to unclipping them without forcing things or flipping out and putting a hammer through the windshield.
Old Dec 10, 2018 | 06:50 AM
442Harv's Avatar
They make a tool to help do this. If they have not been off in years, they are probably really stuck. Pull the wiper from glass, then pull the barrel splined off , must try to keep it square with the post, so it pull off and not bind to one side, to side.The tool helps you do that.
Old Dec 10, 2018 | 07:45 AM
I believe the OP is asking about removing the blade from the arm, not the arm from the post. The Chassis Service Manual is your friend:
Old Dec 10, 2018 | 08:12 AM
72455's Avatar
1972 U code Supreme
Yep...this is exactly how I did it...easy peasy .
Old Dec 10, 2018 | 08:25 AM
442Harv's Avatar
Yes Joe, I think you are correct, I did not read it right. Recovering from major surgery, may not be thinking as good as I think I am.
Old Dec 10, 2018 | 09:16 AM
Destructor's Avatar
Thank you, I was on the right track but wasn’t sure if I would break something or bend something that wasn’t meant to be bent so I left them alone. I have removed the arm from the post on a Cadillac I had. They are set up the same way. The car is away for now until spring. May change them during the winter. I had previously just replaced the blades with refills.
Old Dec 10, 2018 | 03:19 PM
Rock Auto has refills of all sizes and manufacturers.
https://www.rockauto.com/en/tools/wi...r+blade+refill
Jim Kniola
Body work
Apr 8, 2019 06:45 PM
denf221
Feb 23, 2017 09:42 AM
stlbluesbrother
Aug 9, 2012 08:38 AM
Napoleon Solo
Jan 6, 2012 02:42 AM
Dan Wirth
Dec 1, 2009 06:52 PM
