Rebuilt carb
Rebuilt carb
Ran fine but resently did not want to idle cold. Reached in and set fast idle cam and after warmup ran fine. Today it started fine but soon sputtered as I drove up street. Assumed it was still cold and stepped on gas. Later when warmed up it sputtered and died again at a red light. Started back up and pulled over to check for gas leaks. None so I started home having trouble keeping it running but it got better as I drove. Any thoughts.
found out that my "rebuilt" carb got a pressed in needle seat (instead of threaded design). the thread was stripped so the "rebuilder" drilled it out to fit a press-in style needle seat.
the only thing that keeps these from leaking are two rubber o-rings. cant tell how old they are...but i also had trouble with them.
just a thought...who did the rebuild on your carb?
Not sure yet that it is the carb. I had it rebuilt about a year ago and may have 1000 miles on it. The fuel pump has about 9000 miles on it and could be 5+ years old. The carb is a Quadrajet on a455 motor. It was rebuilt by Barker Gang Garage. I have been putting 102 octane in the car. I am wondering what else could cause the symptoms I described but will probly call him to get his opinion on it. His customer service is very good.
to me it sounds like the choke/ fast idle systems are malfunctioning.
These are pretty simple systems to understand, observe, and troubleshoot.
What level of understanding do you currently have regarding these linkages?
Rebuilt when, and installed by whom? How recent is recently? This weekend, this month?
So while cold, you did the usual one push of the gas pedal and the fast idle cam did not set itself?
I'm thinking maybe some gum or crap about your linkages? Is the throttle sluggish normally?
Checked choke operation tonight. Choke sets fine (with one press of pedal). Car started and idled on fast idle but as soon as I pressed the throttle again (less than a minute later) it dropped off fast idle and died. I also see some gas seepage staining at secondary shaft on base plate as well as from gasket between top plate and main body at front pass side. I checked the front bolts (carb to intake) and they were not as tight as the rear so I turned them about a quarter of a turn and wiped off the gas stains. Drove about 3 miles and parked it. I thought the choke was supposed to step down as the motor warms up so maybe that needs adjustment? Will drive more next chance I get in daylight and see if it still dies out at idle or leaks at top gasket. Thanks for the advice. I am not very good with carb/choke problems.
brandon reynolds
April 10th, 2012 12:06 PM
Aceshigh
July 29th, 2009 03:29 PM
