Rebuilt carb
Old Jan 18, 2015 | 06:27 PM
Gary M's Avatar
Rebuilt carb
Ran fine but resently did not want to idle cold. Reached in and set fast idle cam and after warmup ran fine. Today it started fine but soon sputtered as I drove up street. Assumed it was still cold and stepped on gas. Later when warmed up it sputtered and died again at a red light. Started back up and pulled over to check for gas leaks. None so I started home having trouble keeping it running but it got better as I drove. Any thoughts.
Old Jan 19, 2015 | 02:22 AM
EightballZ's Avatar
found out that my "rebuilt" carb got a pressed in needle seat (instead of threaded design). the thread was stripped so the "rebuilder" drilled it out to fit a press-in style needle seat.
the only thing that keeps these from leaking are two rubber o-rings. cant tell how old they are...but i also had trouble with them.
just a thought...who did the rebuild on your carb?
Old Jan 19, 2015 | 08:30 AM
Gary M's Avatar
Not sure yet that it is the carb. I had it rebuilt about a year ago and may have 1000 miles on it. The fuel pump has about 9000 miles on it and could be 5+ years old. The carb is a Quadrajet on a455 motor. It was rebuilt by Barker Gang Garage. I have been putting 102 octane in the car. I am wondering what else could cause the symptoms I described but will probly call him to get his opinion on it. His customer service is very good.
Old Jan 19, 2015 | 09:19 AM
Octania's Avatar
to me it sounds like the choke/ fast idle systems are malfunctioning.
These are pretty simple systems to understand, observe, and troubleshoot.
What level of understanding do you currently have regarding these linkages?
Old Jan 19, 2015 | 09:46 AM
Professur's Avatar
Rebuilt when, and installed by whom? How recent is recently? This weekend, this month?
So while cold, you did the usual one push of the gas pedal and the fast idle cam did not set itself?
I'm thinking maybe some gum or crap about your linkages? Is the throttle sluggish normally?
Old Jan 19, 2015 | 09:59 AM
As Octania stated earlier, sounds like the choke isn't releasing. With the car thoroughly warmed up is the butterfly on top fully opened?
Old Jan 19, 2015 | 05:55 PM
Gary M's Avatar
Checked choke operation tonight. Choke sets fine (with one press of pedal). Car started and idled on fast idle but as soon as I pressed the throttle again (less than a minute later) it dropped off fast idle and died. I also see some gas seepage staining at secondary shaft on base plate as well as from gasket between top plate and main body at front pass side. I checked the front bolts (carb to intake) and they were not as tight as the rear so I turned them about a quarter of a turn and wiped off the gas stains. Drove about 3 miles and parked it. I thought the choke was supposed to step down as the motor warms up so maybe that needs adjustment? Will drive more next chance I get in daylight and see if it still dies out at idle or leaks at top gasket. Thanks for the advice. I am not very good with carb/choke problems.
Old Jan 19, 2015 | 06:23 PM
Octania's Avatar
You are SO close to a full understanding of the choke and Fast Idle systems. Try a you tube search on this subject. The fast idle cam is moved, at times, by the choke as it warms up. One can manipulate the FI cam into position using the choke plate and/or the weight on/near the FI cam on the carb's RH side. The choke is allowed to move by itself, even if the FI cam is held in position by contact with its adjusting screw, as when the car is unattended on fast idle. Then, when the carb is opened a bit by the operator, the FI cam is allowed to fall down to a postion as currently allowed by the choke- from a little lower down to regular curb idle speed.
Old Jan 19, 2015 | 06:36 PM
Gary M's Avatar
Will do the u tube search to learn how to adjust. Thanks again.
Old Aug 6, 2021 | 10:28 PM
Cutlass Fan's Avatar
Check your timing, late timing will cause a bog. Also a carb kit and adjusting your floats and secondary opening may help, It helped my car.
Old Aug 7, 2021 | 04:44 AM
dc2x4drvr's Avatar
Old post..
brandon reynolds
Apr 10, 2012 12:06 PM
wolfman98
Aug 20, 2010 05:21 AM
WTony
Oct 16, 2009 03:56 PM
olds4life
Jul 3, 2009 12:08 PM
