Rear end gears
Old Nov 11, 2018 | 08:22 PM
Davew's Avatar
Rear end gears
hey guys -I need some help. I decided to check my rear end gears. I jacked up the car and put it in neutral. I rotated the tire and the drive shaft rotated about 1-1/4 turns before my tire made a rotation. I checked several times because I didn’t believe it. I even did 4 rotations, and I counted 5 rotations of the drive shaft. I also tried both sides. Any suggestions?
Old Nov 12, 2018 | 07:38 AM
Both wheels need to freely turn in order to get a correct count when doing it the way that you did, and that is hard to do (impossible?) without a limited slip rear. Without a limited slip diff, the wheels will not both turn the same amount and the differential action will result in what you are experiencing.
Block one wheel to prevent it from moving at all, then count the wheel / driveshaft rotations again, and multiply by 2 to get the actual gear ratio.
Since you got 1 1/4 turns of the driveshaft for one wheel rotation, I suspect you have 2.56:1 rear gears (1 1/4 x 2 = 2.5).
Phoenix8990
Drivetrain/Differentials
Sep 26, 2019 06:31 PM
Natedawg
Apr 26, 2019 09:14 PM
1971 442 convert
16
Jun 27, 2015 12:28 PM
kstern58
15
May 9, 2014 08:24 PM
442b
Oct 14, 2010 02:46 PM
