Rear end date code
Old Jul 13, 2020 | 04:12 AM
Cruzinbill's Avatar
Rear end date code
How do you verify the rear end date for an O type rear end?
Old Jul 13, 2020 | 06:57 AM
442Harv's Avatar
What year do you have? 68-72, have a letter stamped on left side for the month, and number for the day, but no year stamped.
Old Jul 13, 2020 | 08:48 AM
Cruzinbill's Avatar
Verify year of rear end
The rear end is in a 72 cutlass parts car. It is TM ratio code. Has 402227 casting number. It has the sealed bearing axle plate. Just trying to verify the year. Has the12 bolt cover.
Old Jul 13, 2020 | 10:00 AM
green1972's Avatar
TM AND sealed bearing with a 12 bolt cover sounds like a 70 12 bolt with 342 gears
Old Jul 13, 2020 | 10:02 AM
The 8.5" corporate 10 bolt rears were used in 1971-1972 Cutlass vehicles. The rearend casting number you posted is for the 1970 O-Type rear, so someone swapped rears at some point.
Old Jul 13, 2020 | 11:32 AM
Cruzinbill's Avatar
Thanks for the input. Supercars unlimited noted in their rear end info that the early production 70 rear ends used the sealed axle bearing as opposed to the open axle bearing. Anyone else find this to be correct?
Old Jul 13, 2020 | 01:04 PM
Seems I recall that a year or so ago someone here on the forum had posted pictures of a 1970 housing with sealed axle bearings. maybe search on that casting number and see if that thread turns up.
Old Aug 4, 2020 | 12:19 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Anyone know what S A means on rear?
hopefully not 2:78 open
Old Aug 4, 2020 | 12:44 PM
Codes are located in front pages of CSM.
Old Aug 4, 2020 | 12:47 PM
My 1971 CSM demonstrates application 31-400 Exc. W-30, 2.73 gear ratio, 41:15 gear teeth differential.
Old Aug 4, 2020 | 12:49 PM
Olds Specialist LOL
so its a 2:73? open?
Old Aug 4, 2020 | 12:51 PM
And, yes STD 8 1/2” w/ 10 bolt cover - NOT anti-spin.
Old Aug 4, 2020 | 01:05 PM
Olds Specialist LOL
Bummer,
came across a 71 Hardtop
black car in epoxy primer
new interior not installed yet
rebuilt 455 15k
thinking about getting it, I guess i would have to do the rear
Old Aug 22, 2020 | 09:54 AM
Mjnorris's Avatar
Hello everyone! I’m trying to find the correct rear code and eventually the correct rear end for a 71 442 W30 4 speed. At some point the rear end in my car was swapped out for a 12 bolt posi. Any help would be appreciated. And a photo of how it should look too if possible. Thanks
Old Aug 22, 2020 | 09:39 PM
Mr Shifty Sidney's Avatar
Mjnorris
There were 3 ratios available from the factory for 71 W-30s. 3:23, 3:42 and 3:73. Will need some more info to narrow the possibilities.
- Air Cond W-30s were all auto/3:23
- Is your car a factory 3 or 4 core radiator without air cond? 3 core would indicate a 3:23 or 3:42. 4 core would indicate 3:73.
- Is your car an auto or 4 speed?
- 3:42 was the standard gear for 71 W-30s
Don W
Old Aug 23, 2020 | 04:41 AM
Mjnorris's Avatar
Mr. shifty, we are getting close!. Factory 4 speed, no a/c, no power brakes and a 4 core radiator. It’s also a convertible if that helps. In the response please let me know if it’s a 10 or 12 bolt. Almost there. Thanks. Mjnorris
Old Aug 23, 2020 | 04:52 AM
So with rhat info I would think a 3:73 would be correct. 10 bolt.
Don W
Old Aug 23, 2020 | 05:00 AM
Mjnorris's Avatar
Thanks! Any ideas on any visible coding on the axel or housing?
Old Aug 23, 2020 | 05:07 AM
3:73 for 71/72 W-30s are stamped TO on axle tube.
Don W
Old Aug 23, 2020 | 05:21 AM
Mjnorris's Avatar
Your help is greatly appreciated! All the best Mr. swiftly
Old Aug 23, 2020 | 06:31 AM
You're killin' me Smalls.
That gear ratio would be 3.73:1 and not 3:73.
Old Aug 23, 2020 | 08:18 AM
Mjnorris's Avatar
Does that mean your daily driver is not 3.23 as written in you auto bio but 3:23:1...... just saying. Also can anyone post a picture of how the stamp on the axel would appear ?
Old Aug 23, 2020 | 08:19 AM
Mjnorris's Avatar
lol
Old Aug 23, 2020 | 08:56 AM
Mjnorris's Avatar
Does anybody have any pictures of what the axel stamp looks like. Looking to see who the TO stamp looks. Thanks.
Old Aug 23, 2020 | 09:09 AM
Where did you get that? 3:23:1 means there are three gears.
Old Aug 23, 2020 | 09:28 AM
Below are pictures of the O-Type rears in my inventory showing the code on the passengers side axle tube.
1968 "TL" code (3.42:1 ratio, open carrier, HD 31 spline axle shafts)
1970 "R2" code (2.56:1 ratio, open carrier)
Old Aug 23, 2020 | 10:04 AM
Mjnorris's Avatar
Finally!!! Kenneth, thanks you. How hard will it be to find the correct rear end for my Olds? I guess I’m looking for a 10 bolt corporate rear end with the TO code stamped on the passenger side. 3:73 posi. Any and all help. Or should I just never mind and live with the 12 bolt. I just missin* a few original parts. Rear end, distributor fuel filter. Thanks to Kenneth and this site. Mark
Old Aug 23, 2020 | 02:41 PM
Sorry, you said you were looking for the stamping for an O-Type rear. Your 1972 car would have a corporate 8.5" 10 bolt rear, not an O-Type as those were last used in 1970.
If you have a Chevy 12 bolt, that is a very strong and desirable rearend. Unless you were wanting to restore everything to show quality original, I see no reason to change it for a different rear. Having said that, assuming you could locate a correctly date coded 3.73 TO code rear, you would be able to sell the Chevy 12 bolt for a decent amount of money, likely enough to cover the cost of the TO code 10 bolt.
The corporate 8.5" 10 bolt code is in the same location but is different as it incorporates the GM division and the date along with the gear ratio designation.
This is the axle stamp on the 1971 8.5" corporate rearend from my convertible. The info I was able to get says:
R2 = 2.56:1 gear ratio, open carrier
0 = Year (?) still not 100% on that
068 = Julian date (68th day of the year)
Old Aug 23, 2020 | 05:04 PM
Mjnorris's Avatar
Kenneth, this is the best no so far and thanks! I have a 71 W30 4speed. You wrote 72 in your findings. Does the info change? Mark
Old Aug 24, 2020 | 08:10 AM
Sorry about the year difference, I saw that you posted the rear was in a 1972 parts car. Anyway, the stamping would be the same for 1971 and 1972.
Old Aug 24, 2020 | 02:03 PM
  #31
Kenneth, the first "O" is actually an O and in between N and P, signifying Oldsmobile production. The fact it looks like a zero is likely just laziness on a factory working stamping the axle.
Old Aug 24, 2020 | 02:47 PM
  #32
That is what I originally typed, but then I got to second guessing myself since the two characters looked like zeros. It is an Oldsmobile produced rearend as it has a block "O" on the forward facing areas where the axle tubes attach.
Old Aug 25, 2020 | 09:40 AM
  #33
ThaDeuce's Avatar
Frankenstein 442 owner
N
I am so glad those are stamped what appears to be upside down. For the life of me I couldn’t find my code 6S in the CSM, then I realized it was actually S9 (3.42:1 anti-spin), 🤣
cdoering
May 22, 2019 02:14 AM
oldsbuff455
Jul 29, 2015 01:13 PM
easyd
Jul 24, 2015 07:13 AM
booray
Feb 21, 2015 12:12 PM
Redog
Nov 27, 2012 04:09 PM
