Questions
Old Dec 28, 2014 | 01:47 PM
jankyrre's Avatar
Questions
Going to town for some shopping tomorrow.
My car and manuals are in my workshop,and the road are not plowed yet.
Does anybody know the sizes on the fuel hoses ,fed and return,on a -68 442.
I am going to connect it to an external fuel tank.
How many quarts ATF does a TH 400 take?
Can I use ATF as powersteering fluid?
Old Dec 29, 2014 | 07:34 AM
Tedd Thompson's Avatar
Well I know little about those new fangled 1968 model cars so I will let the more knowledgeable chime in but I have used ATF in my power steering for years (probably 40 years) with no problems at all....Tedd
Old Dec 29, 2014 | 09:40 AM
Octania's Avatar
Does anybody know the sizes on the fuel hoses ,fed and return,on a -68 442. I am going to connect it to an external fuel tank.
3/8 inlet hose [ID]
That's all you really need. Cap the fuel pump 5/16 tube with 5/16 hose if need be. No need to return fuel to your handi-tank.
around 14 I think, depends on how drained it was- new converter or just a filter kit, etc.
Certainly. More or less the same pump and use of pressurized oil.
Old Dec 29, 2014 | 10:00 AM
jankyrre's Avatar
Thanks.
Dug myself into the workshop this morning.
The SM says 10qts.in the transmission.
Is there a good proceedure for filling it with oil? It is empty except from a little
in the convertor.
Old Dec 29, 2014 | 11:20 AM
Add 7 qts, start it and check in park, add more as needed until full. Then shift into drive and then reverse, check and add as needed. Take it for a ride, check again.
Old Dec 29, 2014 | 02:47 PM
z11375ss's Avatar
Senior Moment Member
That stuff has to be thicker than my skull. Good luck pouring!
Old Dec 30, 2014 | 04:41 PM
ATF is that thick?....Tedd
Eirik
Sep 22, 2006 08:26 AM
hrazor35
Sep 17, 2006 06:45 AM
tarps3
Aug 11, 2006 03:35 PM
shirleys_cutsey_classic
Mar 9, 2006 01:10 PM
