Question about a '65 330
Old Mar 20, 2013 | 02:41 PM
Hey all
I've got a 65 F85 I was going to work on but now have decided to part it out. It has a fairly good running 330 and I'd like to take it out and sell it, but I've heard there are different kinds of 330s and some are not good to work with.
Is there any truth to this, and if so how do I tell which one I have? The car is a late 64 build with a two speed automatic.
Thanks much.
Old Mar 20, 2013 | 04:28 PM
ent72olds's Avatar
Registered Luser
Mike, is it the 4bbl hi comp Cutlass engine or the 2 bbl Jetfire? The high comp engine is the same one used in the '64 442, with the exception of water pump. I'm sure someone will correct me if I'm wrong....if I'm right, the hi comp is much more desireable! By the way, like your sig line.....
Old Mar 20, 2013 | 04:52 PM
All 330 motors have forged cranks. The model year 1964 motors have a number of one-year-only items, that include the water pump, damper, timing tab, and shaft mount rocker arms with unique heads. I think that makes them less desirable except to someone restoring a 64. The 65-67 motors are nearly identical. Even the low compression version is 9.0:1.
Old Mar 20, 2013 | 06:40 PM
Thanks Erik and Joe. I know I read here somewhere about angled pushrods or some such thing, I don't have luck searching a million messages, but if someone can point me in the right direction that's good too.
My car is a 2bbl Jetfire. I can find the engine number tomorrow if that helps.
Also, the trans is a 2 speed, is it a Powerglide(like a Chev) or does it have anything in common with it?
As for the sig line, I felt bad that out of all the cars I have only two of them are Oldsmobiles, so I decided to make them all Oldsmobiles, at least in print.
Old Mar 21, 2013 | 07:37 AM
Well, actually, the 66-67 blocks have the 39 deg lifter bank angle, whereas the 64-65 blocks have the less common 45 deg lifter bank angle. This isn't an issue for building the motor; you just need to be sure you have the correct cam.
The two speed trans used from 1964-69 is the Super Turbine 300 (ST300), also called the Jetaway by Olds. The only thing it has in common with a Powerglide is the fact that it's a two speed automatic. Nothing interchanges between the two. The Olds versions have a switch pitch torque converter, as well.
Old Oct 6, 2013 | 07:28 AM
ankerclanker's Avatar
65 f85
Good Morning, I was given your handle by a member on the 442bro site, he said you might have a rear bumper for sale. I have a 65 f85 that is crying out
for a new or at least better bumper. Hope to hear from you.
tks
ankerclanker
Old Oct 6, 2013 | 01:42 PM
Sorry, ankerclaner, I still have the car but the back bumper is a twisted, rusted freak.
dave84
May 3, 2011 11:28 AM
JeremyTA
Feb 14, 2011 09:23 PM
Iragh
Jan 17, 2010 02:52 AM
Liegekiller
Jun 12, 2009 09:09 AM
hardrider442
Apr 30, 2007 08:19 PM
