Power Steering Squeal
New power steering pump, new PS hoses, new steering gear, new PS fluid, new PS belt. Fully bled the new steering gear with front wheels off the ground. However, turning the steering wheel with front wheels on the ground, there is a squeal noise. With the engine running, the steering has power assist, but tightens a bit with the squeal. More bleeding needed? Faulty PS pump? Thoughts?
X3...the original PS belt was 1/2" wide. Current replacement belts vary, some are 7/16", some 15/32", they may even give you a 3/8" (not likely, but possible) belt. The belt has to be tight, it will stretch, you will maybe need to tighten it again later.
Car? Engine? Accessory bracket configuration? Are the PS pump brackets installed properly with the correct spacers in the right places to ensure pulley alignment?
There are THREE fasteners that you need to loosen to adjust the belt, the two bolts on the front and the one nut at the bottom rear of the pump. Once you loosen all three, use a large screwdriver as a pry bar and insert it between the nose of the pump and the tab on the bracket, between the pulley and the bracket. The photo shows the proper position of the screwdriver with the pulley removed for clarity. Use the screwdriver to tension the belt while tightening the two bolts on the front, then get the nut on the back. Failure to do this properly is why there are frequent posts about belts squealing.
Thank you all replies.
It's a 350 no A/C, Joe. Yes, the brackets and pump are installed correctly with all of the correct spacers/washers. The pump pulley is perfectly aligned.
I'll re-tighten the PS pump belt. I was not aware that some replacement belts may be narrower than OE. The 32-year old belt was in decent condition, but given its age, I thought it was best to replace it.
Follow-up question: The new PS belt is the type that has the cogs / teeth. Should I re-install the old belt which didn't squeal? My concern with tightening the belt is that a tighter belt puts extra stress on the pump bearings and leads to premature failure. Thoughts?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
AJFink
Oct 16, 2018 09:59 AM
