Power Steering Box Leak. Need Insight.
Old Mar 7, 2015 | 09:31 AM
plonka's Avatar
After lowering my 76 Cutlass, I noticed a pool of fluid under the power steering box. I haven't had time to dive into the task yet, but by looking at the pictures, what do you guys think happened. The fluid obviously shot up, hit the underside of the hood and collected on the right side of the radiator support. Possible hose fitting failure or leak maybe? I'm just hoping it's not costly. Let me know if you guys have run into similar problems. Cheers!
Old Mar 7, 2015 | 10:28 AM
Looks like the high pressure hose is bad. In any case, once a leak gets caught up in the spinning fan, oil can get thrown anywhere.
Old Mar 7, 2015 | 01:08 PM
pogo69's Avatar
morgan
You could try giving the lines a snug down. Have someone turn the steering to see if its from the gear or lines after you snug it
Old Mar 7, 2015 | 01:42 PM
The hose should be available through your local auto parts store if its the culprit.
Old Mar 8, 2015 | 06:28 PM
plonka's Avatar
It was the high pressure hose. I cleaned the hose, fired up the engine, and the fluid started seeping from the top of the hose. I also noticed several other blisters forming in the hose. Looks like I'll be ready for the huge annual classic car show here next week. As always, thanks to all for your input. Cheers!
1Fastolds
Ninety-Eight
May 3, 2015 07:50 PM
scott_442
Jun 20, 2014 10:48 AM
1965cutlassragtop
Jun 18, 2011 09:40 AM
Imueller
Jun 2, 2011 09:59 AM
Del70
May 19, 2010 02:50 PM
