posi rear
posi rear
I got a chance to buy a rear out of a S-10.For my 74 Omega. 3.73 gears posi , I guess it's a locker?For $300.I know it will take some work to make it fit,but does anyone know if it will hold up?Any input would be helpful.
railguy
railguy
Fyi
You can use the carrier & gear set from the S-10 & put them in your original housing. They are both 8.5" differentials. Making the S-10 housing fit into the Omega will be a huge PITA.
railguy
I guess I'll forget about the S10 rear.
I know a guy who has a posi "carrier"? out of a Grand national that suppose to fit dose anyone know any thing about those?Not sure of the year but it was bought for a 74 Omega.He couldn't find the spring that goes in it so he bought another unit,now he knows where to get the spring.I'm trading him some parts for it.I have a 74 rear that I'm taking with me when I go to swope with him.I'll check to make sure it fits before we complete the deal.Can anyone tell me anything to look for.There are 3.42 gears that go with it.
railguy
railguy
I have a 74 Apollo rear I took apart and I thought it was 26 splines.I guess I'll double check today.Maybe I should just take mine apart some time.Winter's just about here 36 degrees this morning.
railguy
railguy
The Turbo 3.8 GN G body Posi Unit and 3.42 gears for that matter (8.5 28 spl) is a direct fit to your 74 X body (8.5 28 sp) and forget the S10 idea as 99.9% of S10 are little 7.5 in both 26/28 spline and it would be a Gov-Lock POS style "Gov-Bomb" not a regular Posi like the 8.5 car. , very few S10 Zr2 4x4 around for parts and also the very very rare 2wd 4.3 V6 5 speed S10 8.5 rear are around. No such thing as a 6 lug S10, thats 1/2 ton truck talk. The Zr2 8.5 S10 rearends besides being 8.5 ring gear and 30 spline are just a wider track than the regular S10 .. If you wanted to buy new alloy Mosier or equivelant 30 spline C clip style stock length axles for your Omega then you open up to easy to find 30 spline 8.5 Auburn style Posi units out of 90's Impala SS, Caprice , Buick Roadmaster cars, wagons, taxi, police.. My dad has a 92 ish Roadmaster wagon that is a 3.23 Posi. so thats a great source for both gears and Posi on a budget.
Put a ford 9" in it! Although since you have a corporate 8.5" you could grab a new carrier and gears and install it in your housing with one of those diff covers that help keep the carrier caps bolted down to the housing. I have seen 10 bolt diffs hold up to a lot of abuse at the track. My main reason for going with the ford 9 is because I have a friend with a jig to narrow the housing, and i already had half the parts I needed to install it. at the end of the day I probably have 1k into my rear axle but its a 4.11 detroit locker its 2" narrower than stock, and it has S10 blazer rear disc brakes mounted on it. ( something else you can look into is installing S10 blazer/pickup disc brakes onto a corporate 10 bolt housing, its not that hard )
nj_cutlass72
Nov 20, 2019 09:11 PM
69OldsCutlassS
Drivetrain/Differentials
Sep 9, 2009 01:05 PM
