Please Identify 1111935 distributor
Old Aug 12, 2019 | 10:12 AM
yorkman's Avatar
I have a 1969 Olds points distributor # 1111935 date code 8L7
Can someone with a 1969 shop manual tell me what engine and model it came from? Thanks, Bob
Old Aug 12, 2019 | 10:31 AM
android 211's Avatar
Distributor
With Google I see reference to Toronado and 442, 1969
Old Aug 12, 2019 | 10:33 AM
Distributor
Manufactured 1968, November 7
Old Aug 16, 2019 | 06:25 PM
yorkman's Avatar
distributor 1111935
Thanks guys, but can someone look up the exact fitment in the 69 chassis shop manual? See the chart in engine tune up section 6C. I have one to sell. Thanks
Old Aug 17, 2019 | 08:12 AM
MI68442W30's Avatar
it is not listed in Mondello's technical reference manual and I don't see it in the 69 CSM . are you sure you are reading the numbers correctly? what car did it come off of and do you have any pics of the numbers?
Old Aug 17, 2019 | 09:05 AM
From the Jan 1972 printing of the parts book, that is a run-of-the mill 455 4bbl distributor, used on 1968-69 full size cars. Specifically not used in performance or Toronado applications.
Old Aug 17, 2019 | 05:50 PM
yorkman's Avatar
1111935 distributor
One of my friends sent me a copy of a page from section 6C - Engine Tune Up, from a 1969 Chassis manual. It lists all the 69 distributor specs including this one. See Second from the bottom. It is apparently for high compression 455's (except W-34) My 68 & 70 chassis manuals had the same chart in the same section 6C.
except W-34
Old Aug 17, 2019 | 06:05 PM
Note the W-34 option applicability for the 1969 Toronado. The standard 455 engine of this model year was a 375 h.p. engine. The W-34 option was the 400-hp engine. This distributor was only applicable to the standard Toronado 375-hp engine.
Old Aug 17, 2019 | 06:27 PM
Sorry, but that's not correct. The '935 distributor was used on EVERY high compression 455 except performance versions like the W34. That means Delta 88s and Ninety Eights in addition to Toro. All 4bbl versions of the 455 were high compression in 68 and 69. As I said above, here are the pages from the parts book. Note also that the H/Os used a different distributor.
Old Aug 17, 2019 | 06:37 PM
Right-on, Joe. I should have perused the following. DEALER SPECS 1969. Thanks for the clarification.
1k442
Nov 21, 2017 05:02 PM
70-Olds-442-convt
Jan 16, 2017 09:32 AM
mrolds69
Dec 30, 2015 11:58 AM
smietana
Aug 3, 2014 12:10 PM
perro
Jun 4, 2007 10:43 PM
