Pitman Arm
Old Jan 30, 2022 | 05:11 PM
olds70supreme's Avatar
Pitman Arm
I'm going to need a ps pitman arm soon to convert back from manual steering on my 68 Cutlass. New are available for $60. Are these considered a wear item, or am I ok just getting a used one?
Old Jan 30, 2022 | 06:06 PM
oldolds88's Avatar
should be o with a used one,as long as the taper hole wasnt wobbled out.
Old Jan 30, 2022 | 07:43 PM
Sugar Bear's Avatar
X2 oldolds88...Not normally a wear item unless the tapered hole got worn loose which is rare, it's not bent/twisted nor corroded. I'd be more comfortable with excellent original than most reproductions.
Good luck!!!
Cutlass S Starburst
May 4, 2021 06:28 PM
67abody
Jun 6, 2019 07:07 AM
83hurstguy
Feb 6, 2018 06:20 AM
dbuck
Mar 29, 2014 11:01 AM
KevinBN7
Oct 29, 2010 06:35 AM
