Parts don't fit
Old Jul 6, 2018 | 07:34 AM
DRoger5739's Avatar
Parts don't fit
FYI: In working on my 1967 Olds 442 I found that the new harmonic balancer available has the timing mark off by one inch. Also, motor mounts are not correct, you have to order them for a later year olds.
Old Jul 6, 2018 | 08:06 AM
I don't know what motor mounts you got, but a 1967 442 with stock frame mounts uses Anchor P/N 2261 motor mounts. Nearly every motor mount catalog has errors in the Olds motor mount listings, even Fusick.
Old Jul 6, 2018 | 09:14 AM
RetroRanger's Avatar
72 Olds CS
What balancer did you get? I put a Dayton brand on mine and I'm happy w it.
There is also a thread for parts that don't work right you could add yours to the list
https://classicoldsmobile.com/forums...roduction.html
Old Jul 6, 2018 | 10:54 AM
DRoger5739's Avatar
Also, I went through about 5 different Transmission filters before I found one that would fit my turbo 400 (long skinny filter I think AC PF160)
Old Jul 6, 2018 | 10:56 AM
All 1967 TH400s use that filter. If your pan has the "horseshoe" divot in it, it uses that filter.
Old Jul 6, 2018 | 11:28 AM
therobski's Avatar
Joe emailed me other day about my harmonic balancer: Although your balancer states its for 330, 350, 403, 400, 425,455 they fail to mention for the early 330, 400E and 425 they use a different pointer! I have the same issue on my 67 400E. I need a 68 up pointer...
Nemesis
Feb 4, 2018 12:39 PM
1971raresx
Aug 18, 2016 08:22 AM
csouth
Apr 10, 2012 02:19 PM
Beob
Apr 5, 2011 10:14 AM
sklbndt
Apr 5, 2009 04:47 PM
