Our new Technical Editor/Moderator
I want everyone to know about a new function at our website. Joe_padavano is going to be our new Technical Editor/Moderator. He is going to be watching threads/posts that ask questions which many of us may know the answer to but sometimes may slip through the cracks and not get a response on. I have asked him to try and keep an eye out for accuracy of the information we share as well. As many of you know, Joe has displayed quite a bit of knowledge on Oldsmobiles and it seems only right that we have someone to keep us on track in that regard.
Who knows, if he gets a writer's bug he may write a few articles for us as well. Oldsmobile History, documentation, years for certain models, options etc, may be a subject.
I hope this helps everyone and makes our site more useful and a more meaningful part of our Oldsmobile experience.
Thanks.
Thanks.
Thanks and I hope I live up to your expectations. I also guess I should write a formal intro, since I never did.
I've owned Oldsmobile A-body cars continuously since I inherited the family 68 Vista Cruiser when I got my driver's license in 1974.
Note that the Vista received a 425 transplant not too long after I got it (and without the parents' knowledge) and I proceeded to dust off a few of the local hotshots in central Massachusetts as I was growing up (including a 69 Mach 1 whose owner was incredulous). I graduated to a 68 442 that I pulled out of a wrecking yard and completely refurbished (It only took three years!). Since then I've owned about two dozen Oldsmobiles, mostly 64-72 A-body cars.
I moved to SoCal in 1980 with two Cutlii and came back to the right coast in 1987 with five. See attached pictures from moving day. The cool thing is that you get a discount if you fill the car carrier with one stop (there's a Jag and a Chevy crewcab in addition to the five Oldsmobiles). The orange 71 parked above the cab of the truck was featured in the Oct 1985 issue of Car Craft Magazine (pg 106, but who's counting...). It had a tilt front end from VFN Fiberglass, dual quads, nitrous, and a bunch of chrome. Unfortunately it went away in the first divorce (along with the Jag). The truck has been replaced but I still have the other four cars (66 442 convert, 68 W-30, 69 H/O, and 70 W-30). I've added another three A-bodies plus the 64 Jetstar. Unfortunately, all need work and right now the pressures of running my own company and trying to restore the 300 yr old log house on our farm (yes, I had to buy a project HOUSE also...) don't leave a lot of time to work on the cars. My wonderful wife (third time's a charm) is very understanding (which I'm sure has NOTHING to do with her also having an expensive hobby - horses).
Well, thanks again. We'll see how it goes.
Congrats Joe, you have steered me in the right direction a few times. What's nice is you can deliver accurate information without talking down to the less knowledgable, as some other "experts" seem to revel in.
Here's a question for you, I have a 69 350, stock heads (#5) and an edlebrock performer. I've put 2 stock turkey tray manifold gaskets on it already, before it comes out this year I'm about to put the third one on. It doesn't seem to want to seal good. I have puddles of coolant in the runner area and oily tar like crap along the top of the manifold/head joint on the drivers side.
The first gasket was a carquest one, the second came from an engine shop, it was a fel-pro. Is there a better/different gasket?
Tom
Tom
I would suggest you try a paper type gasket such as MR Gasket etc. These are usually thicker and the front and rear rubber seals usually end up too low so silicone is needed on these front and rear. I have found these to work well but must be checked now and then after initial torque-ing of bolts as the paper tends to squish over time. I dont worry about not having the valley tray in place with these but they are available if you think you need one.
...Here's a question for you, I have a 69 350, stock heads (#5) and an edlebrock performer. I've put 2 stock turkey tray manifold gaskets on it already, before it comes out this year I'm about to put the third one on. It doesn't seem to want to seal good. I have puddles of coolant in the runner area and oily tar like crap along the top of the manifold/head joint on the drivers side.
Tom
Tom
I've used the FelPro metal gaskets exclusively. I run a bead of RTV around both sides of all four coolant openings before installation. This is the technique called out in the Chassis Service Manual. Note that the turkey tray has raised bosses around four of the bolt holes at the four corners. These are designed to fit into recesses in the heads to keep the gasket in place when you install it.
It seems Oldsguy has been cooking this idea up for a while. Glad to see good things happening. I can't wait to see an accurate tech section, and I will help out whenever I can. I am far less knowledgeable than many of you folks, but I have had over 10 GM cars, and have kept both of my Oldsmobiles running since I was 15 years old.
Is there an internet address that we should send factual information to if the need arises?
That's what Joe is for, it's up to him how he handles it.
BTW Joe, if after some thought, you think we could use another forum, let me know.
pps; I have used the trimmed turkey tray in combination with paper gaskets and like it, getting those little alignment dimples to line up and have the tray keep it's place can be a real chore sometimes.
Since it seems impossible to get anyone's attention over at 442.com, one of the things on my to-do list has always been to find a way to create an updated Olds FAQ. I wish I had more time to do it personally, but let's think about an interactive way to make that happen. As I've noted previously, the original Olds FAQ is the result of David Brown extracting bits of information from posts made to the old Chubecto mail server ten to fifteen years ago. Much of it was correct (thank Chris Witt for that) but some of it was not.
Padavano don't know jack...
I just hope I don't lose him over on AACA/OCA forums, since it sounds like he'll be pretty busy here.
Joe is one of those folks who has forgotten more about Oldsmobiles than most people could ever hope to know. If he answers your question, it will be researched thoroughly and most important, accurately.
No question this makes the #1 Olds website now. I think "Thanks Joe" is more appropriate that Congratulations. I don't know Joe but have been amazed at how anybody can know as much as he know about a large number of different models. I think the Congratulations should be to the website and all of us who frequent here.
Now if a few people will become more civil, this website will continue to become even better.
Thanks Joe
Thanks Joe
http://tech.classicoldsmobile.com
I would start by making the needed corrections. Next, moving anything suspect, to a "sticky" in a subsection of your new Technical Forum. It would be dedicated to discussing/verifying the accuracy, of each item, before returning it.
A second subsection could be used to discuss the validity of information posted in the other forums.
Norm
Norm
Do you mean as an avatar? If you cannot select one. PM Omicron, he is our technical guru and will be able to help you. If you can select an avatar you might be trying to use a file that is too large, there are restrictions. Welcome to our site. Don't be afraid to start your own threads, we don't mind.
having trouble replying at times
I've had some problems when I try to reply to someone who has answered a question for me. I get messages saying I'm not logged in or I don't have permissions even though I know I'm logged in already. Any way I just wanted to thank Joe for answering my differential questions on my 87 olds.
Clutch,
I had some difficulties with that too. If you browser is Internet explorer that may be the problem. I had that and switched to Firefox instead, not suggesting you use that in particular, but try a different browser. Also, try it with cookies turned on if you haven't already. If you still have trouble you might need to consult a computer guru. It is probably in your browser, not the site.
Dan
Dan
Joe- You've been doing a great job ! I just noticed that you've been restoring a 300 year old log house. Oddly enough, so have I . My restoration and remodeling began in May of 1976, and continues to this day. ( There's no end to the work !)
Good luck !
Good luck !
Thanks Joe
Thanks Joe
That's great news! I've seen Joe's name on 442.com for several years now and, more recently, this site. I've always wondered how he knew all that he did about Oldsmobiles, and now I see! Thanks for the bio, Joe, and this is one person who appreciates the detailed knowledge that you have. There are "correct" answers to questions, and then there are "really correct" answers to questions - Joe always has the "really correct" answers. If I can be of any help to you, Joe, I'll do my best. I have a '68 442 that has been in the family since February 1969, and a '69 442 that is a work in progress. My first car was a '69 442 that I bought in New London, CT, in April 1972 for $1800! I'm a detail/all original/numbers correct sort of person (also have a '71 Corvette and that's where the numbers correct stuff came from) but have still learned so much more from you and WMachine Kurt. Congrats again on your selection and I look forward to reading your thoughts and answers to questions!
Best Regards, Randy C.
In that case, I don't feel so bad. It's only been 10 years for us so far!
Thanks, Aron. I enjoy your column in JWO.
Thanks Joe!
You've definitely been a huge help with some of the random questions I've brought to the board over the last 2 or 3 years. Even when you don't help directly, your advice usually points me in the right direction when I do back searches for information.
Keep up the good work!
-Russ
-Russ
I just don't understand how someone can put out a book, call it a "restoration guide" when it's not, and then have little to zero help on the trim tag decoding. I'd love to do a better Olds guide/restoration book some day.
Valuable Asset To Classic Olds!
I just read the thread on Joe P. joing up and I want to send a welcome to him. I've read alot of info. on various sites pertaining to vintage Olds cars and his name keeps cropping up under the credits. Good luck in your new venture, Joe! Jim
Last edited by jimjr; Jun 6, 2009 at 01:45 PM. Reason: Wrong surname initial- whoops!
