Opinions: Which spark plug is best fro Starfire
Old May 26, 2016 | 09:29 AM
starman63's Avatar
Have 65 Starfire and want opinions on which to use. has 425 and original uses AC 44s. just a driver not performance car. Don't like Autolite. Thanks
Old May 26, 2016 | 09:37 AM
Why not stick with the AC44's?
http://www.sparkplug-crossreference....t/AC_DELCO/44S
Old May 26, 2016 | 10:06 AM
starman63's Avatar
I wanted to but many places don't list them. Didn't know if modern plugs made any difference in better power, burn cleaner, last longer and I maybe using point conversion.
Old May 26, 2016 | 11:46 AM
None of that really matters, just use the brand of your choice that cross references to the AC 44.
Old May 26, 2016 | 08:12 PM
jaunty75's Avatar
What's wrong with Autolite?
Old May 26, 2016 | 08:51 PM
starman63's Avatar
had a truck that ran fine and gave it new Autolites and truck misfired. ck wiring everything still misfired. Bought Champions it ran great. friend of mine had similar problem. This was 25 yrs ago I never tried them since. Maybe someday.
Old May 27, 2016 | 09:37 AM
I bought a used car with Autolites once. When I went to change the plugs, one cracked around the hex, leaving the threaded portion in the head. That was the first and last time for me.
Old May 27, 2016 | 01:55 PM
rocketraider's Avatar
Oldsdruid
Find yourself some old stock 44s or R44s and you should be good to go. Just be aware that the 44 is also used in Chevrolet and Pontiac musclecars which has driven the price up. You could also try a 45 (one heatrange hotter) but that might be inviting detonation in a high compression engine on today's gasoline.
The only plugs my stuff absolutely didn't like were Bosch Platinums. I've even had good luck running Motorcraft plugs in Olds engines.
Old May 27, 2016 | 02:41 PM
Run to Rund's Avatar
Autolite 85.
rcrac3r
Jul 21, 2012 03:22 PM
L&L Auto Restorations
Jul 11, 2012 05:59 AM
dephconn24
May 8, 2012 11:05 AM
craftsman1956
Jul 7, 2010 08:29 PM
<james.reinhart@detroitdie>
Jul 24, 2004 09:34 PM
