oops that was dumb..storing on convertible top ?
Old Jul 31, 2013 | 06:58 AM
VikingBlue's Avatar
assumed I'd have no trouble finding space in my garage for a Thule cargo carrier when I bought it but it's much bigger than expected...which it really dumb of me b/c the specs are advertised.
until I figure out what to do long term...is there any reason I shouldn't lay it on my 71 A body convertible roof ?
It weighs 60 pounds...and wifey doesn't want it on her minivan when we're not traveling.
Old Jul 31, 2013 | 07:19 AM
I don't like to store anything on a convertible top. Why not hang it for your garage ceiling with hooks and chain above your car. Then just make sure your car is out of the way to remove and rehang.
Old Jul 31, 2013 | 07:26 AM
VikingBlue's Avatar
yea eventually I will build something to hang it from the garage ceiling joists...but knowing me that might not be for a few months.
When I bought I thought I'd put it in the garage attic through an opening I can climb through...but the carrier is too long to move through the opening and lay it down (very low ceiling in attic).
Old Jul 31, 2013 | 07:39 AM
Professur's Avatar
If it's in the garage, put the top down and store the container on top of the seat backs.
Old Jul 31, 2013 | 07:43 AM
VikingBlue's Avatar
Merci !
Old Jul 31, 2013 | 08:10 AM
Professur's Avatar
De rien
Old Jul 31, 2013 | 08:12 AM
Grace Stinespring-Welch's Avatar
x2 build a shelf or something
Old Jul 31, 2013 | 08:31 AM
jaunty75's Avatar
I wouldn't put anything heavier than a ping pong ball on my convertible's top.
But the car IS mostly parked in the garage with the top down, and I DO put stuff in the back seat!
Old Jul 31, 2013 | 08:35 AM
wmachine's Avatar
Trying to remember member
No, I wouldn't do that. Tops should not be stored in the down position!
Old Jul 31, 2013 | 08:42 AM
stevengerard's Avatar
I'd try not and certainly wouldn't recommend it. But 60 lbs shouldn't do any damage. Before I put my new top on I'd put stuff on top of the car occasionally.
Edit and as Kurt already said much better to store car with top up than down.
Old Jul 31, 2013 | 09:21 AM
lshlsh2's Avatar
71 cutlass convertible
OOPS I don't think my top has been up in 2 years!
Larry
Old Jul 31, 2013 | 09:40 AM
Professur's Avatar
True, but they shouldn't have containers piled on top of them either.
Old Jul 31, 2013 | 10:09 AM
QMaster's Avatar
Do you have room to hang it on a wall? We have one and it hangs on a bar attached to the wall. They are big!
Old Jul 31, 2013 | 10:28 AM
oldsguybry's Avatar
NOVICE car nut
If I actually could afford a vert , I would be upset if a fly landed on my top , let alone store something heavy on it .
Old Jul 31, 2013 | 10:30 AM
VikingBlue's Avatar
Bikes hanging on wall on one side, garden tools hanging on the other side, and boxes on shelves on back wall.
but how hanging on bar ? different than hanging from joist ?
more info: I have a hardtop too but I thought laying on the convertible would be a better option...but is it ? or better to lay on the hardtop with a blanket so it won't scratch ? the convertible roof is flatter than the hardtop roof, which is why I thought it would distribute the weight better
Old Jul 31, 2013 | 04:50 PM
64Rocket's Avatar
Don't be so lazy, spend an hour , hit the hardware store and hang it from the ceiling joist.
Gene
Old Jul 31, 2013 | 05:43 PM
68conv455's Avatar
The more stuff I get the more creative I need to become. This is my Thule car top ski box. It will also hold 4 suitcases as it is quite large. I use a pulley system to raise and lower it, I attach extra loops after it is raised for safety.
Good luck
Disclaimer - don't try this at home. I'm a professional
Old Jul 31, 2013 | 05:45 PM
z11375ss's Avatar
Senior Moment Member
Gene
Ha! Problem solved! I guess you just need to do what you need to do and get it over with. Invite a couple of buddies over with some beers on Friday and have a guys night out in the garage. I do this every so often when I want to see my buds. As you guys can relate, it's hard to get your close friends together and when you do, it is great. You're glad you did it. Now get hangin!
Old Jul 31, 2013 | 07:29 PM
VikingBlue's Avatar
not laziness...too many kids requiring/deserving too much attention, too many rides here and there, and with too much crap in the garage which combined with my own crap has created this dilemma.
Old Jul 31, 2013 | 09:31 PM
Lady72nRob71's Avatar
If worse comes to worse, place a soft blanket or upside down rug on your hood, then a layer of that thick packing foam and put the box carefully on that.
I have done things like that in a pinch due to limited space.
Down side is that it gives less motivation to take a quick cruise!
Get a creative storage method planned for that soon.
Folding tops should be stored up to keep them wrinkle free. Also it keeps them stretched to fit. If it is down too long, it may become too hard to put it up again, esp in cooler weather. Forcing it will cause damage.
They also keep dust out of the interior...
Tom Eggers
Aug 11, 2014 12:49 PM
olds88royalvert
Apr 27, 2014 08:42 AM
joe_padavano
Vista Cruiser & Wagons
26
Aug 11, 2013 09:21 AM
1970cs
Jul 10, 2013 01:11 PM
Olds64
Jun 7, 2010 12:43 PM
